Would not automatically downshift when going uphill in top gear
What may be causing this issue of not automatically downshifting when going up a steep grade? I am guessing that it is related to the transmission. I am aware that besides transmission-related causes, there are many other potential causes related to the engine, but am inclined to rule those out because the engine is in great condition.
- Turn the key to position 2.
- Press the gas pedal all the way.
- Continue to keep the gas pedal pressed for at least 10 seconds.
- Turn the key to OFF, position 0. Don’t remove the key.
- Release the gas pedal.
- Wait 2 minutes. During this process, the key is left in the ignition in the OFF position.
I would also recommend to service the transmission with new oil and filter.
the other fail mode is transmission protect mode when the vehicle speed sensor fails and you are locked in second gear.
you need to have an Indy or a Mercedes tech read proper Mercedes codes, and perhaps reset the adaptations using a proper Mercedes scan tool
The trans diagnostics are quite comprehensive. Buy yourself a half decent scan tool for probably no more than $300 and you'll not only see what codes you have, but which ones you don't.
what I learned from that debacle was that on the diesel, an engine condition will trigger a tranny locked in gear, and a tranny fault will dump all boost. So one affects the other.
It should be simple to connect an aftermarket transmission cooler. Probably want to get one with a thermostatic crossover valve. The transmission fluid likes to be in a specific temperature range.
Second time I was towing a 4500 lbs boat (about 6000 lbs total) in 70 degree weather. I noticed it locked gears as well but this time I was on a much shorter incline and was at the top by then. It only does this on inclines while towing and never on flat land or downhill.
