Halogen Headlight Assembly Replacement
Anyway, here's my questions:
1. Does anyone have or know where to find a video of the headlight assemblies being replaced on an X164?
2. Is it really necessary to remove the bumper, or can it just be loosened? I've read conflicting claims.
3. If you changed your headlight assemblies on an X164, did you encounter any particularly difficult or unexpected things involved with the change?
4. I am planning to use TYC headlight assemblies. I know they are not OEM, nor the "best" available. But I do have a budget to consider. Does anyone have any bad experience with this brand? I've used them to replace my fog light and DRL assemblies and while they clearly weren't as heavy duty as the OEMs, they fit, look and work just like the OEMs. I'm also considering Hella, which, at least in the old days, was the go-to premium lighting brand.
5. Although the assemblies come with bulbs, I plan to replace them with LEDs. Can anyone recommend specific LED bulbs that (a) have a great pattern and brightness (b) did not cause any codes or other compatibility issues (c) do not have/require an external resistor pack (d) did not require any modification or special adapters (that were not provided with the bulbs) and (d) do not use fans for cooling (although this isn't that important)?
Thanks!
Part numbers 1EL 263 400-011 and 1EL 263 400-021 are probably what you need, but the country descriptions are somewhat cryptic.
https://web.tecalliance.net/hella/en...r:19344;page:0
Sorry, I haven't replaced them myself yet, so I can't be of help there. Good luck, let us know how it goes!
Easily done, usually with an external resistor pack.
Oops, you need that to fool the CAN bus.
Strongly recommend using a cooling fan. The LED dumps a whopping amount of power into the diode, which all has to be conducted away for bulb life. It is just a fact of life with LEDs; especially the more power you put into them, the more power that has to leave as heat. In the halogen bulb, much of that power leaves as infrared; in the LED, all the excess power is trapped in the diode.
I'm contractually obligated to point out that replacing the projectors will result in substantially better output than just putting bulbs in the stock projectors, but if you do, I'd recommend Diode Dynamics or Morimoto 2 Strokes rather than random Amazon bulbs.
If you are okay with opening up the headlights, you can purchase just the lens and replace them. Will probably be cheaper and higher quality than an aftermarket headlight set. While you're in there you can also retrofit to proper bi-xenon projectors or a proper LED projector.
If you want to do a projector retrofit, the original projectors are the Hella E55 type (no relation to the Mercedes E55). You can use the Mini D2S 4.0 E55 adapters or the EvoX-R, which is an adaptation of the E55 projector and uses the same mount points.
