Zero compression in one cylinder GL550. M273 engine
The bushings in the intake manifold wear and fall out. You can see them at the 6. picture, the small white parts. After 100-150k miles i would think about swapping the manifold. Pierburg manufactures the Manifold for mercedes, aou can get it direct from them for cheaper.
I had EXACTLY the same damage (S211 E550). Bent valve at cylinder 5, zero compression, rocker arm broken, marks on piston head. Your Motor ate his intake manifold, the plastics. Small parts crush your spark plug head, i had this bevor, big warning sign. Big parts get stuck at the valves, boom contact. I repaired it at home without a lift, difficult but doable. You need some special tools and elbow grease. I took a gamble und didn´t pull the piston. The cylinder walls were very good for 250k miles, some minor scratches. Now the car is running fine for 10k miles, full power no oil consumption. All in all a 1000$ repair, the intake manifold is 500$ alone.
If you wanna see pictures, i got many.
