Rattle in front end?
I’ll try to attach a photo.
N e help identifying this part or a permanent fix for this problem would be appreciated!
Now that I see this photo I can see that this blue foam is not very compressed as I thought it would be. N e way, what the heck am I dealing with here???
Honestly, I would have expected much less "rattle" and much more "heavy thunk/clunk" between those two pieces.
I have a rattle in the front - I believe it's actually coming from INSIDE the top of the gas strut.
The pieces of metal that were rattling together were not big heavy pieces like suspension components but more like 1/8” thick sheet metal.
I may end up taking it to the dealer to get a definitive answer but you guys can usually troubleshoot this stuff for me and I very much appreciate that!
Unless I am badly mistaken, the GL is a uni-body chassis, not a body-on-frame, design, with things such as the motor and transmission resting on crossmembers bolted to the unibody.
(Regarding the pictures, perhaps take a wide-angle shot and then zoom in.)
MB part #: 166 331 00 42
I got the feeling that my dealer had never had to order these before which raises my suspicion that I may be on the wrong track???
Hard to describe the rattle but it doesn’t seem to be related to any of the troubleshooting you did AND my little Thinsolite pads ALMOST eliminate it.
I had a horrible rattle clicking that took a while to find … I kept disconnecting front end parts and swaying the body.. Mine ending up being the inside tie rods that were out on before I bought the car .. they were super tight and the clicking rattle was from the inner ???
1. If you suspect the front end .. start by disconnecting the torsion ends..
2. Than try the tie rods…
mercedes etc
3. I even let the air out of the front bags and pulled the bottom bolts
4. Lots of trouble shooting on Youtube videos with 164 chassis noise.
good luck and keep us informed !
I’m not in the market for a knuckle busting job that may not even solve the problem.
Has n e one on this forum ever heard of this part failing??
Maybe I should remove one to find out much of a problem it is. Prices range from $140 at dealer to $24 aftermarket.
are you sure there was anything there to begin with?
The only rattle, crack, pop noise I Experience from my front end is when the airbag is not sufficiently tightened onto the strut, or the sway bar links are worn out.
I think it highly unlikely this is your root cause. The assembly you are looking at is what holds the motor up. Not only would it be exceptional that those bushings fail, both, on opposite sides, but if it rattled it would be a very heavy clunk.
I have never used them, but "chassis ears" might be your tool of choice.
I would again highly advise to watch as many trouble shooting videos as you can… That is how I finally tried the inner tie rods..Buying a good removal tool really helps also.
The 4 rubber bushings you are referring to looked pretty bad on my GL550 but that was not my issue.
I’ve checked everything and watched lots of YouTube vids. I refuse to do all of the work to R&R one bushing after another hoping the rattle goes away.
It bothers me enough that I’ll undoubtedly keep trying to pin point it but I don’t think it’s an existential threat.
