2008 Mercedes GL450
Old Apr 22, 2024 | 09:33 PM
clb0099's Avatar
‘16 Mercedes GLE450 amg,’15 Mercedes gla, coupe,’07 Mercedes w221,’12 Audi A
2008 Mercedes GL450
Hello,
So I replaced my amp a few years ago and it was working perfectly fine. Recently after it rains the sound goes out. I have checked the amp under the driver’s seat and it’s dry and no corrosion. I am thinking water is getting into the quarter panels where the rear sam as I see water pooling u on top of the subwoofer. There are zero codes on Mercedes Star.. anyone have this issue? Where else can I look?
Old Apr 22, 2024 | 11:46 PM
vesiadog's Avatar
1998 SL500,2011 GL550,2009 ML350,past 1995 E320 Cabrio ,2005 ML500,2006 ML500,1996 SL500,1972 280SEL
Rear sam
Originally Posted by clb0099
Hello,
With no codes you are going to have to start somewhere. I would reach under the rear Sam and see how wet the insulation feels .. You might want to pull the rear Sam and look the board over for corrosion. That is a real bad area where the rear taillight lens gasket might need to be replaced . good luck
Old Apr 23, 2024 | 07:12 AM
clb0099's Avatar
Thank you for the response. So I noticed that there is water getting into both sides of the quarter panels. I also am in the middle of taking off both rear interior quarter panels to inspect the electronics (Sam). The issue I am having is that I don’t see updated rear tail lights gaskets like the w164 model. Lastly I have read that the water could be coming from the roof rack bolt holes..
Old Apr 23, 2024 | 09:23 AM
eric_in_sd's Avatar
2007 GL450
I have not done anything about the taillight gaskets. My impression is they were installed backwards, or swapped side to side.
There are multiple potential points of entry. The roof rack, definitely. The panoramic roof panel is another, as is the sunroof.
