Spill. - lots of water went behind ashtray
Old Apr 24, 2024 | 04:49 PM
Uranium238's Avatar
1987 Porsche 928 S4, 2009 Mercedes E350, 2011 Mercedes GL450, 2003 Mercedes ML350
Exclamation Spill. - lots of water went behind ashtray
Before I go on a tirade and get served with divorce papers, what exactly is behind the ashtray, after about 6 oz of water flushed right into the crevice between the bottom part of the ashtray and center wood trim with the cupholders? So far I have not heard any complaints about strange things occurring. I've asked to shut the Command off ASAP when that happens, but I'm concerned there is wiring to TCM and CAN Bus behind there.
Will update if something bad really happens, but any tips on what to look out for would be appreciated.
Old Apr 24, 2024 | 08:02 PM
vesiadog's Avatar
1998 SL500,2011 GL550,2009 ML350,past 1995 E320 Cabrio ,2005 ML500,2006 ML500,1996 SL500,1972 280SEL
remove all clean
It will take less than 10 minutes to remove the ash tray, command center and clean everything up.
wood panel preys up from the bottom.. ash tray out remove the 2 screws … command center has 2 screw than pull the metal tabs down … youtube video it.
Old Apr 24, 2024 | 11:48 PM
DennisG01's Avatar
'08 GL 320 CDI
Yup, amazingly simple to remove things. But the water is already gone - it's leaked down underneath the carpet. 6 oz is nothing to worry about - it's a tiny amount - it won't cause any issues and will evaporate pretty quickly.
Old Apr 25, 2024 | 02:22 PM
Uranium238's Avatar
Got quite a bit of water out. The wiring harness to the ashtray and cigarette lighter were saturated. I wrapped paper towels around it for absorption.
As of this morning, no strange electrical faults. I'll keep an eye on it still.
Thank you everyone for all your help
