Hard shifting (GL450 '06 x164)
Also if I am in a traffic jam driving in 1st gear and slowly braking, it feels like I am on the edge of turning the engine off the whole time because of low rpms.
(I know that's normal but the car shakes a bit too much and too often when driving in that condition).
Should I get the transmission valve body and the conductor plate replaced? Or is it something else?
Also I am not sure if it's a 722.6 or a 722.9 transmission.
Thanks in advance.
Cold
the 7G rarely sees first gear in normal use.
if you have a first year X164 it’s gonna be the 722.9, aka the 7G. It has seven forwards and two reverse speeds, thereby the .9.
See if you can replicate it by manually shifting D3-D2-D1 and do both when cold and warm.
symptoms of the conductor plate failing is the transmission locked in second gear as a limp mode.
I rebuilt my 2008 with new Orings after some Limp mode issues and cleared it up and also helped the shifting . The Orings get cracked and allow pressure to get by them or Orings fall off completely . In the picture with the blue Oring broken was on one of the brake controls and the error was “trying to put two gears in at once”.
Also my experience with 7 speeds..2006,08,09,11 the worse by far was the 2006 in a ML500. We had to send the board off and get a few sensors replaced.. We constantly had errors popping up. There is a source in Jersey with a great turn around time.. I can get that info from my son he sent the board.
Ok good luck and let me know if I can help???
