GL350 Bluetec 2010 – PT-CAN Bus-Off on Hard Acceleration
Old Sep 10, 2025 | 02:32 PM
GL350_Sweden's Avatar
Hi all,
2010 GL350 Bluetec (X164, 722.9). Car drives and shifts normally, but under hard acceleration (from standstill or while driving) I get a PT-CAN bus-off.
Symptoms:
  • Cascade of errors (ESP, Pre-Safe, Airmatic, TPMS, DSR, etc.).
  • “No CAN message from N15/3 (EGS)” and related codes (U0103, U113B, P172A, U021200, 9339, 9100).
  • Reproducible under strong throttle, regardless of engine temp.
  • Fault clears by itself after a short while while driving.
  • When scanning, all codes appear as stored/historic, none active.
Already checked:
  • No oil intrusion at 722.9 pilot bushing.
  • Wiring splice under passenger floor is clean/dry.
  • Central Gateway inspected – completely dry, no fluid ingress.
  • Happens both cold and hot.
Has anyone else experienced this on GL/ML/X164/W164/X204? What was the root cause and fix in your case?
Thanks!
Old Sep 13, 2025 | 02:14 AM
No one?
