2011 Mercedes GL350 Bad EIS
Old Jan 26, 2026 | 11:10 PM
tesslinger's Avatar
2011 Mercedes GL350
I've been trying to troubleshoot what could possibly be a BAD EIS and would like any feedback. Typically, in the morning at first startup, I get a "Drive to workshop without changing gears" or SRS Restraint Sys Malfunction Service Required" message. I can "resolve" this problem by removing the 7.5 amp fuse that goes to the EIS for around 30 seconds and put it back in. Most times the vehicle will start and run fine for the day. There's been two times in the last two or three weeks where I had to do it twice, after the instrument cluster threw a fit of warning messages. It appears that the CAN bus goes inactive and is not able to wake up until the EIS is power-cycled. I tried disconnecting and measured the X30/19 connectors/CAN C bus. I received 120 ohms of resistance between the CAN H to CAN L. I also measured resistance of all nodes; most for 25K or 52K ohms, except two. The ESP measured opened (It appears the ESP nod isn't energized until the EIS or other component powers it on). The Oscope showed signs of life once the key was powered on. The Steering Column module measured 126 ohms between CAN H and CAN L. Here are all of the stored codes that collect over the past 24 hours. I just replaced the engine and had to replace the bad battery (the vehicle has been sitting for around 8 months was at 8.5 volts). It's possible that part of the wiring harness could have become damaged during the transfer, but I don't think it's that. There were no electrical problems that I'm aware of when it last ran during the summer, but now it's winter.Here are the codes from the scan, along with the rollup below it (Report also attached):
CDI 60LS-Common Rail Diesel Injection
ID Status Description
118100 Stored Relay N10/1kC (Circuit 87 relay, engine) of component N10/1 (Front SAM control unit with fuse and relay module) switches off too late.
11FD00 Stored(Event) One or more signals sent from control unit N15/3 (ETC [EGS] control unit) via the CAN bus is implausible.
ETC-Electronic transmission control
C141 Stored(Event) No CAN message was received from control unit N73 (EIS [EZS] control unit).
C002 Stored CAN controller: CAN bus OFF
C001 Stored CAN controller: CAN bus OFF
D13A Stored(Event) No CAN message was received from control unit N80 (SCM [MRM] control unit).
ESP-Electronic stability program
7223 Stored(Event) CAN signal 'Ratio' from control unit N15/3 (ETC [EGS] control unit)
is implausible.
7250 MIL ON&Stored(Event) No CAN message was received from control unit N80 (Steering
column module).
5020 MIL ON&Stored(Event) Chassis CAN bus:CAN controller: CAN bus OFF
5026 Stored(Event) No CAN message was received from control unit Transmission control.
5557 Stored(Event) No CAN message was received from control unit N51 (AIRmatic with ADS control module).
AB-Airbag
91B6 Stored(Event) CAN controller: CAN bus OFF In the case of the fault 'Bus OFF' the
control module is isolated from the CAN bus because of a major communication fault.
TPM - Tire pressure monitor
D03288 Stored CAN bus OFF fault EZS-Electronic ignition switch
900516 Stored Terminal 30 NOT PRESENT
900887 Stored No CAN message was received from control unit A80 (Intelligent servo module for DIRECT SELECT).(ESMESM Timeout)
ISM-Shift module
P124088 Stored The CAN bus has a malfunction. Bus OFF
U016887 Stored(Event) Communication with the electronic ignition lock has a malfunction.
The message is missing.
OCP-Overhead control panel
9700 Stored(Event) CAN reception timeout: N73 (EIS [EZS] control unit).Do not replace control module OCP. Continue troubleshooting in control unit EZS.
9701 Stored(Event) CAN reception timeout: N93 (Central gateway control unit).Do not replace control module OCP. Continue troubleshooting in control unit CGW.
UCP-Upper control panel
9020 Stored(Event) No CAN message was received from control unit N73 (EIS [EZS] control unit).
HBF (Rear control panel)-Rear control field
SAM-F-Signal acquisition and actuation module front
9008 Stored Component E2e2 (Right low beam) is faulty or the lead has open circuit.
904B Stored(Event) Control module N73 (EIS [EZS] control unit) is not sending any data.
904D Stored(Event) Control module N80 (Steering column module) is not sending any data.
REAR SAM-Rear signal acquisition and actuation module
C30E Stored(Event) Event:Signal 'Vehicle speed' on CAN bus is not present or is faulty.
ESA driver-Electric seat adjustment driver (with memory)
9852 Stored(Event) Fault in CAN communication with control unit EZS.
ESA passenger-Electric seat adjustment passenger
9852 Stored(Event) Fault in CAN communication with control unit EZS. SCM [MRM]-
9345 Stored(Event) Fault in CAN communication with control unit EZS.
9354 Stored(Event) Fault in CAN communication with control unit CGW.
9348 Stored(Event) Fault in communication on engine CAN databus.
REDC-Rear-end door closing control module
C16800 Stored(Event) Communication with the electronic ignition switch is alfunctioning.
RevETR-RF-Right front reversible emergency tensioning retractor
U000188 Stored(Event) Drive train CAN communication has a malfunction. Bus OFF
U016800 Stored(Event) Communication with the electronic ignition switch is malfunctioning.
RevETR-LF-Left front reversible emergency tensioning retractor
ASSYST-Active Service System
9204 Stored Control unit ASSYST is not receiving any messages from the engine compartment CAN bus.
ASSYST PLUS-PLUS Active Service System
B1204 Stored Please refer to vehicle service manual!
PTS-Parktronic system
9057 Stored(Event) No or incorrect CAN message from control unit CGW
905D Stored(Event) No or incorrect CAN message from control unit LCP
905C Stored(Event) No or incorrect CAN message from control unit Dr-side SAM
XALWA-L-Xenon headlamp, left
9060 Stored(Event) CAN message 'Wheel speed' or 'Stop lamp switch' from control unit ESP is missing or is faulty.
9062 Stored(Event) No CAN message 'Steering angle' from control module SCM [MRM] or message is faulty.
9064 Stored(Event) CAN message 'Main beam' or 'Light sensor' from control unit CGW is missing or is faulty.
9065 Stored(Event) No CAN message 'Yaw rate' from control module ESP or message is faulty.
9066 Stored(Event) One or more messages from control unit IC are not available on the CAN bus.
9067 Stored(Event) No CAN message 'Transmission mode' from control module Transmission or message is faulty.
906A Stored(Event) One or more messages from control unit Transmission are not available on the CAN bus.
906C Stored(Event) CAN timeout fault
9071 Stored(Event) No CAN message 'Terminal 15X' from control module EZS or
message is faulty.
XALWA-R-Xenon headlamp, right
9004 Stored Status of terminal 56b implausible
9050 Stored Short circuit of ignition auxiliary voltage (outside control unit)
9051 Stored Component E2e10 (Right bi-xenon lamp with integral ignition module) is defective.
906C Stored CAN timeout fault
COMAND or AUDIO
C168 Stored(Event) Communication with the electronic ignition lock has a malfunction.
A27D Stored(Event) The watchdog function has detected an internal software error.
Automatic scanning results
System Name Status/Count
01-CDI 60LS-Common Rail Diesel Injection Fault | 2
02-ETC-Electronic transmission control Fault | 4
03-ESP-Electronic stability program Fault | 5
04-AB-Airbag Fault | 1
05-TPM - Tire pressure monitor Fault | 1
06-EZS-Electronic ignition switch Fault | 2
07-ISM-Shift module Fault | 2
08-OCP-Overhead control panel Fault | 2
09-UCP-Upper control panel Fault | 1
10-HBF (Rear control panel)-Rear control field Fault | 1
11-SAM-F-Signal acquisition and actuation module front Fault | 3
12-REAR SAM-Rear signal acquisition and actuation module Fault | 1
13-ESA driver-Electric seat adjustment driver (with memory) Fault | 1
14-ESA passenger-Electric seat adjustment passenger Fault | 1
15-SCM [MRM]-Steering column module Fault | 3
16-REDC-Rear-end door closing control module Fault | 1
17-RevETR-RF-Right front reversible emergency tensioning retractor Fault | 2
18-RevETR-LF-Left front reversible emergency tensioning retractor Fault | 2
19-ASSYST-Active Service System Fault | 1
20-ASSYST PLUS-PLUS Active Service System Fault | 1
21-PTS-Parktronic system Fault | 3
22-XALWA-L-Xenon headlamp, left Fault | 9
23-XALWA-R-Xenon headlamp, right Fault | 10
24-COMAND or AUDIO Fault | 2
25-CGW-Central gateway Pass | No Fault
26-SCR-Selective Catalytic Reduction Pass | No Fault
27-Suspension Pass | No Fault
28-KG-KEYLESS GO Pass | No Fault
29-WSS-Weight sensing system Pass | No Fault
30-DCM-FL-Door control module front left Pass | No Fault
31-ERA-Electric fold-down backrest system (3rd seat row) Pass | No Fault
32-HS-Seat heater Pass | No Fault
33-AAC-Automatic air conditioning Pass | No Fault
34-UCI-Media interface Pass | No Fault
35-SDAR-Satellite radio(Valid for USA) Pass | No Fault
36-AVE-H - DVD player Pass | No Fault
37-Left rear screen Pass | No Fault
38-Right rear screen Pass | No Fault
39-TELE AID-Control unit Pass | No Fault
40-TELE AID-Telematic services Emergency call Pass | No Fault
41-TELE AID-Telematic services MB Info,Roadside assistance(USA, Canada),Telediagnosis(ECE) Pass | No Fault
42-TELE AID-Telematic services Stolen vehicle tracking Pass | No Fault
43-TELE AID-Telematic services Remote door unlocking,Remote door locking Pass | No Fault
File Type: pdf
Old May 5, 2026 | 08:13 PM
haitham600's Avatar
MB 2010 GL 550
So when you changed the engine which ECM did you install?
CAN C is shutting down. Front SAM is not related to the rest of CAN C. I would check there. Under driver seat. Check for water pooling. All original CAN C immobilizer modules must be original to the vehicle to work. Engine, transmission, EIS, ISM, not sure if others are. But cluster, TPM no, SRS, maby.
Old May 5, 2026 | 09:25 PM
tesslinger's Avatar
2011 Mercedes GL350
I didn't replace any of the control modules, just the engine. I'm thinking that it may be an open or shorted connection with the transmission when it's cold. It runs perfectly fine when it's warm and no rain. When it's cold (below 40F), I often times need to reset the EIS, restart and it runs fine. If it rains, sometimes the front parking sensors go off when I'm driving down the road and the automatic wipers don't seem to have a coherent frequency. Sometimes the error doesn't happen until I'm driving down the road; the cluster will go whacky and the transmission doesn't shift smoothly. This is normally resolved by resetting the EIS. Some other codes that I've received when that happens can include the following (mainly as pending codes).
U0402 - Invalid Data Received From Transmission Control Module
U0002 - High Speed CAN Communication Bus Performance
U0037 - Vehicle Communication Bus B
U0146 - Lost Communication With Gateway "A"
U0416 - Invalid Data Received From Vehicle Dynamics Control Module
U0101 - Lost Communication with TCM
