Compass
Old Feb 4, 2026 | 01:00 PM
Pmanc's Avatar
2012 gl450
Compass
Hi all I have a Gl 450 in the last few weeks on the dashboard. The compass has not been working and when I put the car in reverse the rearview camera does not work then I shut it off and then it’ll work is this have anything to do with the cold or could it be something else? Also when this happens I’m not able to change the radio station from my steering wheel Any ideas? thanks
Old Feb 4, 2026 | 07:17 PM
Max Blast's Avatar
NGL450 w/EORP, S550
Does the compass work on the command screen?
Old Feb 4, 2026 | 08:37 PM
Pmanc's Avatar
2012 gl450
Yes the compass works. But sometimes it just freezes. I wasn’t sure if this could be caused by the extreme cold we have been having
Old Feb 5, 2026 | 09:19 AM
Max Blast's Avatar
NGL450 w/EORP, S550
Well, electrical goofiness is usually water related and when that freezes it could push connectors apart. Have you looked for ice in the trunk?
The compass readout in the dash display is just a repeater of the COMAND system screen where you can read out position, exact heading, number of GPS satellites, elevation and steering angle. If any of those inputs are intermittent or missing there, it could help narrow down which sensor or gateway is having issues.
Old Feb 5, 2026 | 10:07 PM
Pmanc's Avatar
2012 gl450
I believe the command center is working. It’s just not the other function but when I put the car reverse the back up, camera does not work, but this doesn’t happen all the time.
Old Feb 6, 2026 | 02:47 AM
Sallad's Avatar
Veteran: Army
Veteran: Canadian Forces
08 GL320 CDI
Do you have the NAV dvd in? (if it even has one at that year) I believe my GL does that as well because the Nav DVD doesn't work.
Old Feb 6, 2026 | 10:21 PM
Max Blast's Avatar
NGL450 w/EORP, S550
No, no under the center COMAND screen -> NAV -> Compass
There should be a lat/long, elevation, and satellite read out. Confirm that this works.
(I don’t have a degree read out in my dash display because I have the EORP and the diff lock status override that.)
