GL cornering lights not working
Old Dec 1, 2012 | 12:08 PM
firstgl's Avatar
has anyone been able to get them working? i have read similar issue on the 13ML forum.
Old Dec 1, 2012 | 05:37 PM
JimBarnhart's Avatar
2015 Ram 2500, former 2013 GL350, 2007 GL450
Mine worked from the start, so not sure. Is there a disable feature in the center computer setup?
Old Dec 3, 2012 | 04:23 AM
GMW's Avatar
GMW
2013 ML63 AMG PP
Cornering light on an EU type model
One thing I've noticed about the cornering light, (I'm talking about the small seperate LED one that lights up when you reach a junction and turn right or left into it, not the one that used the main Bi-xenon headlight and follows the curve of the road as you steer on a twisty road) they won't light up when you just start up the car and turn the steering wheel at standstill, even if you put the transmission into D. It seems that you first have to drive forwards a bit then when you turn the steering wheel they will activate and shine down the direction you are turning.
For further clarification, I've attached a picture of the cornering light I am talking about.
This system should be the same on the new GL as well.
Old Dec 3, 2012 | 03:27 PM
oh, I was thinking your vehicle wasn't turning the headlights, I see what you are asking now based upon GMW's response.
That's consistent with my 2007 where it turned on the fog lamp on that corner. You had to be moving for it to come one.
Old Dec 3, 2012 | 04:07 PM
blittle's Avatar
2013 GL450 (traded for 2015 Escalade), 2012 Corvette, 2014 Ford Fusion, Previous: 2007 GL450, 2011
Yep.... I had that on the 07 as well BUTT.... I thought they discontinued the cornering light via fog light activation in either 2010 or 11? MY 2011 has the "lighting package" with the led drl's and no fog lights. Maybe somebody can clarify.
Old Dec 4, 2012 | 02:15 AM
fabbrisd1's Avatar
A gaggle of MB's
Speed sensitve in three scenarios see manual page 127 - Neighborhood 1 - which is under 25 mph and use turn signal or with minor steering off-angle Neighborhood 2 - 25-45 with more significant steering off-angle. Highway - over 45 mph offline unless held over for max 3 minutes from prior trip from Neighborhood 1 or 2.
Old Dec 18, 2012 | 01:25 PM
firstgl's Avatar
dealer said thay should work to bring it in. Does anyone have their cornering lights working?
Old Dec 18, 2012 | 02:39 PM
blittle's Avatar
Maybe it's another "phantom option". ...... In the manual but non existent!
Old Dec 19, 2012 | 12:21 AM
fabbrisd1's Avatar
A gaggle of MB's
No, read the manual on what the feature does and does not do... all will become "clear" in Dianetics type way..
Old Dec 19, 2012 | 06:37 AM
jdmmbz's Avatar
2005 Honda Odyssey, 2012 GTR
I hate that weird fog light turing off and on feature. I thought there was a short.
