No Snow mode allowed on the road?
noob Question.
I am not going to offroading with my GL 550 but was wondering if I will ever miss not having Snow mode in winter on icy/snowy mountain roads. The MB manual said do not use off road modes on the road. What is the reason? I use it on my Range Rover Sport going down the mountain in snow and ice at 25 to 30mph. (Yes I am that guy who slows the Traffic until next turnout but I value my skull more). Is it wrong to use it on the road? Once in Range Rover I momentarily lost control in Snow mode and my friend said that snow mode may cause it too. I just feel safer when the low range gears slow down the vehicle and increase the torque. Is it just better put the GL on hill decent mode in Snow/Ice? Is it the same as putting the car in lower gear?
If offroad package will help I can sell this 550 now when there is demand and find/order another with that package.
2013 GL450 (traded for 2015 Escalade), 2012 Corvette, 2014 Ford Fusion, Previous: 2007 GL450, 2011
noob Question.
Well....there are several issues here: first, the "off road" modes ( 1 & 2 ) are separate programs from the "snow" program. The snow program is designed to provide a slower throttle response, a start from stop in 2nd gear, more adaptive shift points and it also applies a a different program to the traction control system with regard to the anti-lock brakes and center differential lock............... all of this with driving on snow covered "normal roads" ...... you can, in fact, activate the snow program anytime ( rain, dry roads ) if you so choose! The two off road programs are designed literally for "off road".....dirt, rocks, mud. Off road 1 can be of help in deep snow , back roads and can be augmented by your own manual shifting of the gears to a lower gear for going downhill. NEVER use the hill descent mode on snow/ice roads..... hill descent assumes a dry "off road' situation. Hill descent will utilize the gearing AND the brakes to maintain the selected descent speed.....in applying the brakes it could cause the vehicle to become uncontrollable on a snow/ice covered hill. So.... in summary, hill descent, off road #2, and low range are really designed for severe off road. Snow program and off road 1 are really helpful in on and off road snow situations....and the off road package allows you the additional capability to raise the vehicle up to a 12in. ground clearance which is also helpful in deep snow. I have had the off road pack. on each of the GL's i have owned because I do travel in some deep snow back roads during the winter.
Another question to owners in Canada and northern states: do you have dedicated snow tires for your GLs? Thinking of getting standard 19 wheels instead of my present 21s and putting maximum allowed size winter tires.
2012 GL550, 2012 E550
We had some deep snow this past winter in omaha. Prob 12-15 inch with some bigger drifts. My 12 GL550 with stock 21's did great. Raised it up as high as it would go, comfort mode plus raise button, and couldn't have been happier. I thought about a set of different tires but thought I'd wait to see how oem ones did and glad I didn't spend the extra cash.
I am glad stock 21' AMGs on GL550 have so much more rubber.
Nice to hear that someone has had good results with the bigger tires in the snow.....what tire brand are the 21"s ?
i've never used snow tires- I find that all seasons are just fine in allwheel drives..
21" for me is no issues, my other GL has 20" amgs with slightly bigger tires (285s instead of 265/275s)- again more rubber, no issues..
as for off road package- my perspective, for regular, deep snow, its a non issue with or without as the total height increase is about the same, without off road you only lose ability to adjust extra mode for slightly less height raise, full height raise seems to be exactly the same. Sport mode essentially the same in both- so in my opinion you'r not missing out on much unless you really go off roading (for which personally i would have a nice 4.0 jeep wrangler, yea i miss my old jeep... - instead of a 100K+ giant) so i didnt get off road in my 550.
i'm told snow tires make a great difference, but I only seem to note that folks without all wheel drive or only with rear wheel drive get them and are extremely happy with it- honestly with all wheel drive i dont think it makes a big difference, heck you'r gonna be driving slower anyway (i hope)
I had all seasons on my range rover and they were just fine too... I also dont feel getting 19s, then getting spacers to fill the wheel well and have tires come as far out as they need to, is unnecessary-- even here in the mid/north west.
for using on road- i believe its not recommended due to limitation of the driving speed. I accidentally pressed the height button while driving and a message came up- drive more slowly- i was like what the heck, then realized it wouldnt raise the height at higher speeds, even without off road package.. and obviously the braking would be directly affected by it too..
all said- i think you should be fine without off road package-- and for those wondering, the 21s with wider tires dont make a significant difference.. my 2cents.
SLS Irridium silver,2014 GL350 BT Irridium, 2015 White Dodge RAM Hemi Quad
Here in Ottawa Canada, my wife's GL 350 has the optional 21" AMG wheels with the all season pirelli scorpion in 295. For the winter months, I bought the pirelli scorpion winter ice/snow tires in the same 295 and have no issue whatsoever. If you buunthe right winter rubber this will not be a problem. Also, just to addmmore food for thought, I did start the winter with the all seasons and they were not very good, they did not give you the confidence that the winter tires did. I didn't want to gamble with my wife and two kids during the snowy months.
1 Post
2012 GL350 Avantguard
What is the size of snow tires in 19s?
Are the chains even allowed on this car and if yes what kind?
Thanks to all for responding because my lack of experience in winter driving is a serious safety topic. Mountain residents have a name for drivers like me. Citidiot. I am trying to learn before next winter to avoid this.
1 Post
I have the 265/55/19 on oem 19 gl rims (they were pretty much brand new from ebay. Still had the oem sticker on the inside).
If you are going the winter tire route and plan to keep the gl for a while I would recommend different rims (especially if you plan to hit the mountains just every once in a while ). Easier to mount and take off rims as opposed to tires.
![drive](https://mbworld.org/forums/images/smilies/driving.gif)
