Escort Radar Install
Old Sep 15, 2013 | 09:48 AM
sam9187's Avatar
2014 S550 - SOLD, 2014 GL550 - SOLD, 2014 GL63 AMG, 2015 S63 AMG Sedan, 2015 S63 AMG Coupe
Has anyone installed a radar detector yet. I want to install an Escort 9500ci but the price I am getting is $1200 for install plus the cost of the radar and cost of mid city engineering module ($450).
Old Sep 15, 2013 | 11:55 AM
Pntblnk's Avatar
2017 S550 Iridium / Black Nappa, 2015 GL 550 Paladium Silver
The MidCity module is worth ever penny if you want a clean install. The 9500 is a marginal detector and the laser shifters are worthless. Take a loot at the Beltronics STiR+. Far better option and will integrate with the MidCity module perfectly.
Old Sep 15, 2013 | 12:01 PM
Trimmer2's Avatar
I had it installed plus the "live" add on. So far, we've had to replace a faulty controller and struggling to get the whole thing working 100%. It's about 95% and close. The Mid City Engineering instrument cluster module is a must with distronic plus. The ONLY time you see the Mid City display is when you're in the Audio Mode in the cluster (radio, Serious etc) other wise it's audio only for alerts. I added a light in the cluster so, it's green but, flashes red during an alert. I put the Live controller and display in the ashtray so, it's covered by both the ashtray flap and the wood cover. There's actually a slight notch (similer to the vent's notch when they are centered) so the cover stays open covering the ashtray and keeping the cup holders available. Once all the local false alarm are locked out, I RARELY have to access the mute/lock out button.
Old Sep 15, 2013 | 07:42 PM
sam9187's Avatar
How much approximately was the cost of install?
Old Sep 28, 2013 | 09:52 AM
wheelsloose's Avatar
CLS63 AMG
Can you possibly take a few pics of where they installed your laser shifters, radar unit and also the inside of where the main controller with audio/mute button is installed? I have my old 9500CI sitting in the garage and need to have it installed.
Thanks.
Old Sep 28, 2013 | 11:06 AM
marsh1's Avatar
GL63
I had a K40 installed in my GL63. Totally hidden and completely satisfied so far.
My installer put blue LEDs behind the turn signal arrows for separate front and rear alarm. I had the Mid Cities remote start installed but with the K40 I saw no need for the display. I wanted the front and rear coverage that the Escort does not have. It does not give as much advance notice as my Valentine 1 but far fewer false alarms so I react as soon as it goes off.
Old Sep 30, 2013 | 12:17 PM
Trimmer2's Avatar
These pics show where we mounted the GPS Antenna and front laser shifters. I would have gone further outboard with the shifters though...and still may.
Live and display are mounted in the ashtray (not the prettiest but, out of sight non the less). USB port and control are in the access space on left of dash. Brains along with Mid City module are up under dash (above brake pedal).
I still may have a more custom/finished approach for the Live and Display but, for now, just happy is all working as designed!
Thanks.
Attached Thumbnails Escort Radar Install-photo-12.jpg   Escort Radar Install-photo-11.jpg
Old Feb 24, 2016 | 10:05 PM
Jim Ma's Avatar
S 550, S65 Coupe
Where did you pass the wires through to get from the engine compartment into the interior cabin?
I am just about to tackle the install and figure that will be the hardest part, finding where to access the cabin with out drilling a hole. Also where did you install the radar receiver ?
Old Feb 25, 2016 | 06:40 AM
mtm's Avatar
mtm
gl450
If you remove the cabin filter enclosure (just a few bolts) on the passenger side of the engine compartment, you will see a rubber grommet with wires going through the firewall into the cabin. If you fish your wire through that grommet, it will come into the cabin at the top of the passenger footwell, on the right.
Old Feb 25, 2016 | 07:22 AM
mist68's Avatar
Carrera S;
Are your turning signals LEDs white or amber?
Old Feb 25, 2016 | 08:57 AM
Neurobit's Avatar
2021 GLE 53 AMG Coupe
They look white because they're not on...
