shifting styles
Night Assist is the biggest waste of money ever. I have it, it's worthless. Even if you thought it was safe, you can't drive by watching the screen - it's at a different magnification than live. And if you think you see something with your native eye and then look down at the screen it will be out of view of the camera.
1st - the major utlility of the paddles is to provide a smoother/faster method to gear down to passing gear with a 3 second hold of the left paddle. In that 3 second gear down - the tranny will shift in the 1st second down one gear - but in the following 1 1/2 seconds shift/jump directly down to the appropriate passing/power gear for that speed which in most general fashion at common hwy/street speed most often can be a additional 2 gear jump. As compared to "kick down" this paddle downshift/power-gear procedure is faster - smoother than common "kick down".
2nd - that same downshift/power-gear procedure also becomes very useful in upcoming situations where the smoother/more controlable downspeed/braking situation that can become smoother by adding engine braking power - often downhill highway exit rampls or going into anticipated serious curves
"Power exit" from either passing or braking situations where power-downshift has been used - either single click upshifts exiting, takes you up one gear at a time - or 3-second right paddle hold will take you to upshift to full auto mode
This has been characteristic of MB tranny systems - the bonus is with 7G and &G+ is that these paddle manuvers with this sophsticated single-clutch efficient transmission are much smoother/effortless - in many cases with new W166/X166 pasenger comfort is increased as well - as a matter fo fact you can have all sorts of fun as a dirver and your passengers blissfully don't even know/feel what is happeniing.
January wait for GL350's - yes - in the next few days both slect slots depending on dealer are still changeable for 450's and select 550's - again depending on specific dealer situations.. those end-Nov slots are closing like Tues/Weds for changes as factory locks down earlier for peak-peak season
