Parking Brake Not Working
Old Mar 20, 2014 | 09:09 PM
jw1977's Avatar
GL450
I don't think my parking brake is working anymore on 2014 GL450, when it was pushed before, a red light would go on the dash, it doesn't do that anymore? Anyone else have this?
Old Mar 22, 2014 | 10:46 AM
jw1977's Avatar
GL450
I take it no one has had this issue? When you guys hit the emergency brake does light come on on the dash?
Old Mar 22, 2014 | 04:01 PM
Steve Maislin's Avatar
2013 GL450
Well, it's the parking brake system or the just the light. So, hop in the car and don't start it or even touch the start button. Press the parking brake button. You should hear the brake actuate and the light should come on. If you hear the brake, then it's the light. If you don't hear anything it then it's one of may things. But, regardless of what you hear or not, it needs to be serviced. To release the brake the ignition needs to be on and you pull back on the switch. In either case you don't need the engine running. Good luck.
Old Mar 23, 2014 | 11:46 AM
jw1977's Avatar
GL450
Thanks, it's definitely a problem with the system not just the light. I guess we'll take it in.
Old Mar 23, 2014 | 06:19 PM
blittle's Avatar
2013 GL450 (traded for 2015 Escalade), 2012 Corvette, 2014 Ford Fusion, Previous: 2007 GL450, 2011
Perfect advice!
