Convert 450/350 to 550
Okay. Mine does, too. I covered the light sensor on the windshield and now all lights illuminate like it is nighttime with no drl strobing.
I will try to add capacitors to the Drls and will report back the outcome.
#34
I believe it had to do with going from the factory 5-led DRL on the 450 to the 7 or 9 led DRL on the 550/63. I thought it was just a coding issue, however, the dealer couldn't find a setting for it. It flickers in the daylight, but is fine at night (when the DRL are set to dim).
#35
Yep, mine does the flickering too. Would think there would be some solution, I guess I need to investigate, as I do like my DRL ON during it day!
#36
