Premature rear brake pad wear
Old 01-01-2016, 06:48 PM
Dog hauler's Avatar
GL350
I have a 2015 GL350 with 45k miles. Recently, the Check Brake Wear warning light came on. I pulled the front wheels and there is plenty of pad left, perhaps 40%. Certainly at least 30%. In either event, not enough to turn on the warning light unless MB is trying to make a few bucks changing pads that don't really need it.
I then pulled a rear wheel and found that the rear pads are, indeed, getting down to where they need replacement. I find this odd for two reasons. First, 45k miles seems a bit early to wear through a set of pads, though I'm sure stopping a 5600# truck tends to wear out pads. The second thing, and I find this even more odd, is that it's the rear pads that are wearing out long before the fronts. I'm thinking that just shouldn't happen.
I tow more than occasionally and that certainly could contribute to faster than normal brake pad wear even though the trailer has brakes. But, it's still very odd that the rears are wearing quicker than the fronts.
Does anyone have any idea why the rears would wear faster than the fronts?
Old 01-01-2016, 07:56 PM
fabbrisd1's Avatar
Received 1,100 Likes on 806 Posts
A gaggle of MB's
If you tow - and or "fully loaded" 45K is admirable - and front brakes good at 45K are exceptional.
At weight - brake system is compensating with more force/blance to the rear brakes for load balance - with tow/hitch - rear SAM is compensates on the individual rears as needed to prevent as lateral rear load with trailer changes - to prevent see/saw.
Old 01-01-2016, 08:33 PM
cyberorth's Avatar
2018 AMG GTR, 2017 GLS63, 2019 C63s
Keep in mind that this car with options like lane keep assist over works rear brakes all the time. I have the same issue with both tire wear and brake wear for the rear. Also I notice in mbs when the rotors thin out due to wear you may get this message which unfortunately means both pad and rotor replacement.
Old 01-01-2016, 08:36 PM
cyberorth's Avatar
Also at those Milages you are doing better than most, tow or not, as Fab mentioned.
Old 01-01-2016, 11:11 PM
Count Laszlo's Avatar
'16 GL550, '12 C350
Rear pads wear faster. It's heavy. More than normal for pads at 45k front or rear... or much, much sooner. Nothing mysterious other than you need to get them replaced.
Old 01-02-2016, 09:52 AM
Elric99's Avatar
2014 GL450
I did some googling and some people are saying MB uses thinner pads on the rears now? I wonder if going with non-MB replacement pads in this case might be worth considering.
Old 01-02-2016, 03:17 PM
Dog hauler's Avatar
GL350
Okay, thanks, though what's "rear SAM?"
Old 01-02-2016, 11:48 PM
luv2sleep's Avatar
'15 GL450
Smaller & thinner rear pads....basically yes, on the newer vehicles. Stability control (whatever they are called these days) uses brakes and other mechanisms to basically keep the vehicle safely on the road. Aggressive driving, especially taking corners fast or driving on slippery surfaces, will put the stability control to work, thereby increasing brake wear. Clear as mud?
Old 01-05-2016, 01:03 AM
taxachusetts's Avatar
'13 GL450
35k miles on my 2013 and I just got the brake pad wear alert. It's for my rears too. I was surprised like DogHauler. I always thought fronts wore out first.
After reading this thread....I now know the real deal.
Old 01-05-2016, 04:57 AM
jbattan's Avatar
2023 Maybach GLS600, 2023 Bentley Bentayga, 2023 Genesis GV60, 2017 AMG GLS63
It was bizarre to me too, but I had to replace the rear pads on my GL 550 at 30,000 miles. The front pads are still going strong.
Old 02-29-2016, 01:46 PM
LIRS6's Avatar
'14 GL550 , '79 911SC
Rear pads at <30K, front pads/rotors just now at 34+k ..
Old 02-29-2016, 08:58 PM
smayshusband's Avatar
2004 E55 AMG 2014 GL63 AMG
GL63 here and I'll be dammed if I get 10,000 miles out of my rear pads before the light comes on for pad wear. Usually about that time I need new tires also.
Old 03-02-2016, 01:07 PM
luv2sleep's Avatar
'15 GL450
We're on our 3rd GL and I can tell you that the GL goes through tires (and brakes) fast. Our '15 GL450 has 18k miles and it needs new shoes already. Soft OEM Continental tires + heavy vehicle=quick tire wear!
Old 03-17-2016, 07:43 PM
SFML320's Avatar
2015 GL550, 2019 GLC350e
41K miles, just installed 2nd set of rear pads compared to none for the fronts.
Old 08-02-2016, 07:39 PM
350gunner's Avatar
GL350
Bumping a slightly old thread my rear pads recently went at 24K on '14 GL350. I assume it's from my city driving but I am not impressed with the life (or the replacement cost). The front are still about 1/2 there.
Old 08-03-2016, 09:15 AM
guhanp's Avatar
2014 GL 350
Just changed our rear pads last week. 28K miles. DIY, not hard.
What I realized was that ONLY the passenger rear inner pad was worn. Coincidentally, this is the one with the sensor. The rest of the pads had at least 20k miles left on them.
Went with OE from getmercedesparts.com. Not cheap.
In my case, it was lane keeping assist pulsing rear brakes. This is my wife's car so no comments...I turned off LKA.
350gunner: Do you have LKA turned on?
350gunner (08-08-2016)
Old 08-05-2016, 08:54 AM
tate16t's Avatar
S550
Does this void your warranty?
Old 08-06-2016, 09:07 AM
guhanp's Avatar
2014 GL 350
Not sure how this will void warranty. Please elaborate.
Old 08-06-2016, 10:23 AM
tate16t's Avatar
S550
Not sure either so I cannot elaborate. My question is, will it void the warranty?
Old 08-06-2016, 11:04 AM
guhanp's Avatar
2014 GL 350
I don't know. It's just brake pads. I used oe pads and sensor. Have receipts. Many forum members have done this replacement. I sure hope Mercedes is not trivial to void warranty over a brake pad change, esp when using oe.
Old 08-06-2016, 02:03 PM
jacobsung's Avatar
18 Model X, 13 GL350, 13 Odyssey, 07 530i
I had the same issue where only rear/passenger/inside pad worn out. I blamed on a stuck sliding pin. MB replaced rear pads at their cost. I did too turn off active lane tracking.
Old 08-07-2016, 10:21 AM
Silver0066's Avatar
2014 GL450
I have noticed that if I have Cruise Control (non active) on and go down a hill, the brakes will slow down the speed if it exceeds the set speed.
Now I turn it off and let it speed up a little.
Old 10-18-2019, 06:27 PM
recklessruss's Avatar
2015 S63 AMG
Uneven brake pad wear-inner wear most plus uneven wear
Old 10-18-2019, 06:51 PM
2015 S63 AMG
W222 S63 Uneven rear brake pad
This is the second time changing the rear brake pads at 41K while the front ones are still going strong. What I I don’t get is that why are the driver side pads wearing out unevenly, mostly the inner pad while the passenger side pads has barely any wear. I then resurfaced my rotors and changed the pads. Now I noticed the same uneven pattern wear on BOTH driver and passenger side pads..
I found this video. My calipers are good.
Not sure if the pins could be the problem.
local repair guy says it’s the lane assist that’s causes uneven wear? Is that true? What could be the problem here.
Old 12-18-2019, 10:40 AM
BS55AMG's Avatar
C55 AMG
GLC300 rear pads and rotors
32k kms, rear pads and rotors, $700 Canadian. I was told it’s normal by the Mercedes dealer. Ouch!
Quick Reply: Premature rear brake pad wear
