how to replace 3rd row seat belt guide
However it isn't trivial how to replace it. I took out the side trim at the end of the trunk (which just pop right off from pulling), poke my head inside, hoping to find a screw that fasten it to the panel. However instead found some sort of plastic peg that hold it in place, not sure how to remove it. Scared to try pry it off by force, worrying it will break that peg as well, and the peg is not listed on the part list, not sure if I can get replacement if if I break it.
Anyone tried this? Maybe I didn't describe this good enough I will try to upload some pictures when I get home tonight.
Last edited by byroncheung; Aug 1, 2016 at 04:43 PM. Reason: provide picture of the question
You mention about removal of the seat belts before, can you give me some advice about this please? Im going to change the C & D pillar trims in my GL63 soon (along with A pillars) because I hate the light grey colour headliner on my black with black vehicle, obviously the C & D pillars will need to detach the seatbelts from the body to remove and refit.
Carl
I note the part number you listed, is that a generic part number regardless of the country of residence? I am from Australia.
Just trying to source one and work out how to fit it.
Thanks for any further help if you have any.
Cheers, Andrew
Cheers, Andrew
Sorry for a reply 2 years late...
