"Pre-Safe Functions Limited" warning plus picture of car rear ending
Old Aug 4, 2016 | 08:34 PM
Agar426's Avatar
2013 GL450
I found more info on my searches, plenty of threads....so I don't want to clog the system. I will continue searching, thank you!
Old Aug 4, 2016 | 09:43 PM
Agar426's Avatar
2013 GL450
See above...
Old Aug 4, 2016 | 10:37 PM
robalo220's Avatar
2014 Black SLK 55 AMG, Black 2015 GL 550, 2011 Blue GLK 350
Ive had it happen in either really heavy downpour of rain or snow/icy conditions where the sensors were blocked by very heavy rain or the ice/snow.
Did you possibly have something blocking the sensors such as trash that fell off after you got home? Just another thought. I'd see if it continues to be ok or if it comes back. If so, then looks like a trip to the stealership for diagnostics.
Good luck
Old Aug 5, 2016 | 10:03 AM
cadetdrivr's Avatar
2014 GL350
Originally Posted by Agar426
Update - I didn't do it on the subsequent trip this evening. I am fearful that it could happen and result in a loss in power in heavy traffic. It didn't exhibit a loss in power, but is that next?
Generally speaking, no. The powertrain and the warning/safety devices are two independent systems.
BUT.....IF the warning is caused by low voltage that could be a concern.
In any event, the easiest solution is simply having the dealer diagnose the problem. As a MY2013 your 450 should still be under warranty, no?
