2013 GL450 Tow Harness
If the hitch was installed at the dealer - and the owner did not want/need wiring - then yes, the dealer could have installed the hitch w/o wiring harness.
If you just need "standard" wiring - then any U-Haul can add wiring connection for you - using Modulite module.
Keep the beat !
"Electronic Stability Program (ESP) with ESP Trailer Stabilization"
Underneath, there is a hitch but no connectors. I'm a bit confused because anytime I've owned a factory installed hitch, there already a connector installed.
For the 2013 GL450, what's the part # for the harness and do I need the dealer to program anything? I do not want to do any u-haul options.
If possible I would get someone to run your VIN number and it would have if it had the trailer option from the factory.
You have a couple of choices if you need to get the electrical installed, either buy; a electrical kit from the dealer ( which I did one time) and had the dealer install it or go to a store that does recreational vechiles and have them install an after market one. I did that on my last two cars.
Do all the GL450 with the factory installed hitch option come standard with electrical connections (where the left hole is)?
I guess I have to make an appointment with MB to get the bottom of this.
1. If the hitch was installed at the factory - it would be listed as "Trailer Hitch" under options - and would include the factory wiring harness including connectors at the back
2. Yes - in your rig the ESP does have Trailer Stabilization - IF the trailer hitch was factory installed OR if MB hotch was dealer installed including wiring harness (big job)
In your case - from what you say - and from what the owner you bought it from - YES it sounds like you have a MB dealer installed but without the additional expense of installing the factory wiring harness.
Frankly - if you just need basic trailer wiring - any U-Haul store can clip that it - with Modulite relay - etc..
