Keyless Go not working
Cleaning the button is easy and fast. Grab some MAF cleaner / Electrical contact cleaner or Zippo fluid and spray the whole button till all the dirt comes out.
Test and see if it works , If the keyless Start still do not work replace the button with the same part number ( Mercedes Dealer would be able to pull out the part number using your vin do not go for aftermarket) it should be below USD 50. The button is the common culprit for this kind of issues
Thanks for the quick reply. Unfortunately, I don't think it's the start button itself. The vehicle didn't come with one, and I picked the car up with the key in the ignition from the dealer. I was in a rush to get the car that day, so I neglected to check the Keyless Go features to unlock/lock the doors, and to test the push button start. I had a respected third party auto-inspection service check out the vehicle before I agreed to the purchase. However, that inspector also neglected to catch the issue. I ordered a new button from Mercedes Benz last week and tried it in the vehicle with the FOB in my pocket: no luck. I'm thinking it has to do with the RF signal antenna, or the key fobs need resetting. Anyone have this issue and find a viable solution?
You might need to send it in to the Mercedes dealership to get it fixed. Is it a CPO vehicle?
The FOB reset technique is for older keys such as the ML up to MY2005. It is the flip keys as they do not open the doors without doing the sync on the FOB.
Another method to do reset is to leave the key in the ignition for 1hour I cant remember if it is at position 0 or position 1.
he did indicated that that he has keyless go and able lock and unlock the car with the key in his pocket
1. touch the little square on any of the door handles? Does it lock the car (if unlock) or re-locked if previously locked? You said previously, it does nothing correct?
2. Put your fingers behind the door handle but not pulling it. Does it unlock the door if it was previously locked?
Repeat for each door handle.
I did discover a strange issue yesterday while testing out all the door handles. The right passenger rear door opens when I have the vehicle locked, which then sets off the alarm. I guess I have a bigger problem than the Keyless Go not working now.
Last edited by NolaGL550; Aug 1, 2017 at 09:49 PM. Reason: incorrect module names listed
