Changing rotors and pads.
http://audipages.com/Tech_Articles/susp_whls_brake_steer/ml350brakes.html
https://mbworld.org/forums/new-m-class-w166/573151-how-repalce-front-brakes.html
https://mbworld.org/forums/gl-class-x166/623174-2013-gl350-x166-brake-job-torque-specs.html
https://mbworld.org/forums/new-m-class-w166/519155-diy-brake-tip-need-11-mm-hex-bit.html
https://mbworld.org/forums/new-m-class-w166/526481-new-brake-pads.html
There's plenty of data in what I linked, plus so much more discussion here that you might search, on which parts to use if not factory MB stuff, or how to get MB parts cheaper if that's your route (my brake engineer buddy says OEM pads with high quality rotors from any source often serve as the best outcome for those who want the same same). Or, just pay the dealer $1000+ and stop thinking about it.
Yes, I'm crabby. And this forum is seriously low on activity lately. It's also super stoopid that W166 and X166 each got split into two groups due to a mere marketing name change (and a barely there mid-cycle facelift) when answers just like this prove common to the entire platform despite if the car is called GL or GLS in our case, so I will never understand the logic here in contrast to benzworld with one forum for all where a guy like Lomtevas shares a running log to benefit both the guy who bought a GL in '16 and the gal who bought her GLS in '17 - same cars. No, there is not necessarily any connection among all these facts.
Now I'm done.
