Engine temperature
Old Aug 12, 2017 | 09:15 AM
Lapsykoz's Avatar
GL 500 x166
Engine temperature
Hi i have a GL 500 x166,
The tempeature is like 92 / 95 degrees.
Is it nornal?
[ATTEngine temperature-img_1111.jpgACH]410966[/ATTACH]
Thank you
Old Aug 13, 2017 | 04:16 PM
Dreamszalone's Avatar
2015 - GL 550
It is normal and being summer with AC On the degrees would be +3/4 extra, and in winter it would be -3/4 degree lesser.
If you see the temp over 98 then its a concern because the water would boil at 99.
But 95-97 is normal and you should be fine.
Old Aug 14, 2017 | 10:19 PM
Isawelvis's Avatar
Veteran: Air Force
, 2023 BMW X4, 1991 190E
Temp gauge
I have a ML350 and it runs the same. Asked the dealer about it and they said it was normal. Not same car or engine but I think you are OK
Old Aug 15, 2017 | 08:26 PM
SaniDel's Avatar
2015 GL 550
Originally Posted by Dreamszalone
<snip>
I would think there's a bit more "headroom" before worrying about boiling. Cooling systems are pressurized, which raises the temperature required for the coolant to boil. Also, the antifreeze added to the coolant raises the boiling point.
Still, your point is valid ... the temperature of the coolant should stay below the boiling point of pure water at normal atmospheric pressure, which is 100º C to be on the safe side.
Old Aug 18, 2017 | 09:14 PM
Jpkcpa's Avatar
2013 GL350
Certainly open to correction, but believe the temp
guage is in C, not F
Old Aug 18, 2017 | 09:17 PM
Jpkcpa's Avatar
2013 GL350
never mind, thought I saw reference to F. Told you I was open to correction.
Old Aug 19, 2017 | 09:50 PM
anothercar's Avatar
2002 C4 Cab, 2014 Audi A5 cab, 2017 X5 35d
My 2015 GL 350 runs at the same temp.......winter......summer........all the time. It's been that way since new and I'm at 47k miles now.
