Adding Factory Trailer Hitch
I'm towing a 5000 lb sailboat. Tongue weight is 400-600 lbs (depending on how we have the boat loaded). We are a family of four (both kids are adult-sized) and with gear for a week, we're loaded up. The airbags pump up to keep the rig level and I haven't experienced excessive tire wear. A straight axel would be better for keeping the geometry right, but that's a concession I make for the smoother ride and better handling. I only have about 1500 miles of towing on this rig. We towed the same with our 2006 ML500. Similar air suspension on a smaller rig. We had a least 5000 miles of towing with that one. The only issue we had was a broken fan belt that had a piece wrap around the fan. Replacing the belt was easy, but I wish I would have realized some of it was wrapped around the fan before we were in downtown Seattle traffic. The truck was telling me something was wrong, but I thought it was a leftover code from the broken belt. Always listen to your truck (and your wife)! We had 200,000 miles on it when we traded it in for this 2015 GL350.
I love the factory sway control. We were at the towing limit of that ML500 and it always performed very well. When we passed a semi or a gust moved us around, it always settled right out. I wanted that same peace of mind with this one. We all have different uses for our rigs. So read a lot here, ask questions, and make the choice that's right for you.
Jeff
Jeff, do you get the Trailer Camera Option when in Reverse? If yes, did you have to enable the "RVC Trailer Mode" in the Hidden Engineering Mode?
I didn't have the option to choose the Trailer View when in reverse. I enabled the RVC Trailer Mode in the engineering menu and then it gave me the trailer icon on the screen. But even if I select the Trailer Camera option, the guide lines do not change...basically nothing changes. I am not sure if I have to change the camera type in the engineering mode as well. Maybe the GLs without the factory towing pack pre-installed have different cameras...just a thought.
Any idea what could be the reason it is not showing me the trailer view even though it gives me the option to select it?
Jeff
Jeff
But with or without the trailer hooked up, the guidelines remain the same.
I just enabled RVC Trailer Mode and exit the engineering mode. For the function to become available, a system restart is required....thus just lock the car and wait 5-7 minutes.
Jeff
I got mine back from the dealer...emissions done...filed the claim and submitted the repair order etc to MB. About 4 days later, I checked my VIN here (https://bluetecupdate.mbusa.com/home), and it shows that the installation is complete and extended warranty applied. It has been about 2 weeks now and still no check from MB.
