I need a scanner to change brakes?!!
Old Sep 2, 2017 | 02:18 PM
DC-BENZ's Avatar
GL350 Bluetec and GLS580
I just watched this video, is this necessary and which scanner does this?
Old Sep 2, 2017 | 02:29 PM
ItalianJoe1's Avatar
2003 CL 600
No, you can release the e-brake with the service menu in the cluster.
Old Sep 2, 2017 | 02:44 PM
DC-BENZ's Avatar
So this video procedure is only for the rear brakes? The front pad indicator just came on yesterday and I'm trying to prepare to do the front job. I've done it on my previous 163 and 164 and am hoping there isn't much if any difference on this 166.
Old Sep 2, 2017 | 03:20 PM
2003 CL 600
Correct, fronts are normal. The rears have the electronic parking brake, which must be retracted electronically so you can press the calipers back to install new pads.
Old Sep 2, 2017 | 04:37 PM
DC-BENZ's Avatar
Thanks, order placed.
Old Nov 18, 2017 | 04:51 PM
DC-BENZ's Avatar
I finally changed my front pads and the brake pad warning light still comes on.
Old Nov 18, 2017 | 04:59 PM
2003 CL 600
You did replace the sensors right? Both front and rear?
Old Nov 18, 2017 | 05:08 PM
DC-BENZ's Avatar
No, the rears aren't worn, I changed the front disks, pads and sensor. I'll double check the rears tomorrow.
Old Nov 23, 2017 | 03:22 PM
DC-BENZ's Avatar
I double checked the rear pads and sure enough they were almost as worn as the fronts. Since I had that one tire off, I decided to go ahead and change the pads and sensor (they came in the mail yesterday). No more brake pad sensor light!
There is an interesting set of instructions to retract the rear electric powered calipers which I found online. Other than that everthing went fine.
Question, is it typical for the fronts and rears to wear at the same rate? They were last changed 35k miles ago per the vmi.
Old Nov 24, 2017 | 08:29 AM
2003 CL 600
Yep, depending on driver habits and conditions, it's not unusual for the rears to wear out similarly to the fronts. That's why I said to check the rears.
Old Nov 24, 2017 | 09:00 AM
DC-BENZ's Avatar
That's a first. Must be the nanny systems and the adaptive cruise because I can certainly feel the rears being used when those systems are activated.
Old Nov 24, 2017 | 10:01 AM
2003 CL 600
Yes, the adaptive cruise and ESP normally uses the rear brakes to pull the car back into line. It's more subtle that way, it doesn't feel like a strong pull.
