Higher Wattage Halogen Bulbs for Low Beams
decided against any upgrade to factory halogen bulbs, which according to manual are H7 55 W ... can I put a higher wattage bulb and cooler temperature halogen bulbs to get brighter and whiter lights WITHOUT any changes, plug and play ... suggestions? Thanks ... disappointed GL450 owner with stock halogen bulbs ... WTF ... John
Received 1,003 Likes
E55, GLS450, GL63, GLE350
Higher wattage bulbs can melt the headlight housing if you go too far. Upgrade to a HID conversion. Make sure to get the bulb with a metal base or you will struggle to get it back in the bulb holder
vivaitalia (09-27-2017)
KK ... gonna experiment with LED "plug n play" with fan motor base to keep bulb cool ... it has one of the highest lumens for an H7 bulb ... hoping the extra motor base will fit inside the housing ... research has shown that a projector housing (my low beams) will not be as bright as a reflector housing (my high beams) ....
You are absolutely right because I currently have on installed on my 2014 GL450 and very disappointed. I am looking for a new kit to replace the LED. Do you know a source where I can purchase the HID kit with metal base?
The following 2 users liked this post by nguy0138:
vivaitalia (09-27-2017),
VRJ (02-15-2018)
No affiliation or experience with this seller but this is basically what I've been using. http://www.ebay.com/itm/55W-HID-XENO...wAPWxsLGIDN1hw
so why am I not surprised that replacing just the bulb, let alone the entire bulb / connector base is NOT user convenient ... so for my 2013 GL450 ... access to the low beams is through the front tire wheel wells ... removing the connector is not a simple plug and unplug ... seriously MB??? anyone has guidance, pictures, suggestions on whether this can be a fairly mechanical person DIY ??? ughhhh so frustrating ...
2012 Mercedes S63 P30, 2015 Mercedes GL550, 2009 BMW 650i Convertible
For me, the driver's side was easy through the wheel well, but the passenger's side was definitely more difficult. Finally got it, though.
Bill
VRJ (02-15-2018)
