Suspension 2013 GL45
OK, have an issue with my rear/passenger suspension drops some time when parked. Happens at least 50% of the time, but no predictable conditions. I always airs back when start the GL, in fact even when I open the hatch i airs back up. Pictures attached passenger rear (lowered) the other is normal driver rear, both pictures taken at the same moment. Anybody else have this type of issue?
Your airmatic suspension developed a hole and it's leaking air. It will only get worse. You should get it replaced. If one fails, others will probably fail sometime later.
