Replace Battery 2013 GL450
I unbolted the negative terminal first (10 mm) followed by the positive terminal. Then I removed the 2 hold down plate nuts (13 mm) and the chassis ground cable to give me more room to slide the battery to the rear. Also I removed the vent pipe from the battery. My carpet had already been cut previously so I did not have to do that.
The hardest part was trying to lift the battery out of its well. After a lot of wriggling I was able to lift the rear end up first to about a 45 degree angle and then pull it out. I was going to place a loop lift strip under the battery for the next time as it would make it easier to lift but I forgot
when inserting the new battery in. Anyway, i plugged the opposite vent hole of the new battery and it was a lot easier shoveling the new battery in the well than taking it out. Reconnected the positive and negative terminals as well as the ground chassis cable, the vent pipe and the tie down plate/nuts. All electrics came back on and the clock was off for a couple of minutes and it reset itself. The only reset I had to do was the side mirrors would not fold in when locking the car. This got reset by navigating the assist feature on the cluster from the steering wheel controls and first disabling it and then re-enabling it. Car started up just fine.The only thing that bothers me is that the old battery was an MB battery that had been replaced by the dealer as part of its CPO program when I bought the car and the battery was under 2 years old (about 22 months) and I had put about 7000 miles since it was replaced. Will see how long this one lasts. The dealer would not replace it under warranty because it was paid for by MB and not me. If I had paid for it it would be covered.
When I mentioned earlier that the battery was dead, there was no warning that i would expect to see from other batteries that are dying. It worked perfectly 2 days ago when the car was last driven, nothing was left on, and when my wife went to start it, with the keyless go, it unlocked the doors and when she went to press the start button - nothing it was totally dead and would not even accept a charge from my CTEK 7002 charger.
i have an issue that is urgent, i am hoping someone here can help. I replaced my battery and followed the instuctions with the key, except that the car car clicks and doesnt start. Does anyone know what the issue is?
I had called Sams Club, but they said that they cannot install batteries unless they are under the hood or in the trunk with easy access.
The battery was tricky to get out and it would have been easier to cut the carpet more if you are not strong enough to pull it out at an angle.
