Rough Idle After Spark Plug Change
Not sure who has any ideas or have dealt with a similar issue. But I decided to do my spark plugs early at 50K miles. The car have ran perfect and now its starting to have a very slight rough idle randomly during stops at redlights. This does not happen all the time, but enough for me to notice. I replaced the spark plugs with the bosch oe plugs. Because of this issue, I went ahead and replaced them again using the factory Mercedes Benz plugs. I also changed out the coil connectors and cleaned all air filters, map sensors, etc. I checked and do not see any vacuum hoses lose or anything like that. I even tried using a fuel injector/stabilizer in the gas. At this point, I only know to replace the ignition coils.
2013 GL550
Thanks in advance for any input.
Good luck!
Just an update. I took the car to a Mercedes autoshop. They ran all tests, smoke vacuum tests, compression test, electrical test, injector test, spark test and everything came back perfect. We ended up replacing the spark plugs again(3rd time) and a whole new set of coils w/ connectors. Currently, it still does it randomly every few redlights. I am just puzzled at this point. Its just very annoying, its a very slight rough idle.
