Any high mileage GL350?
Old Oct 17, 2018 | 10:20 PM
SndsoftheSbrbs's Avatar
2019 Audi Q8, 2015 GL63, & 2005 E500W4
Originally Posted by jacobsung
What's the sign of timing chain going bad?Reply
Rattle and ticking. Also, the car might take multiple 'chugs' to start.
My 2011 R350 BlueTEC is dying. I'm in Illinois and it's so f***ed up. I'm so mad. It was over $70k special order and it's at 92k miles.
Old Oct 17, 2018 | 10:21 PM
I've changed the oil every 3-5k miles too as the technical service bulletin and brochure recommended.
Old Oct 17, 2018 | 10:28 PM
If you live somewhere where it is difficult to find B5 or less diesel—DON'T buy one. Ethanol Illinois killed my car with this B5-B20 standard.
Old Oct 19, 2018 | 12:11 PM
DC-BENZ's Avatar
GL350 Bluetec and GLS580
Which TSB are you refering to?
I too have moved to every 5k miles which is basically when mine starts burning oil.
Old Oct 19, 2018 | 12:35 PM
I was told that there was a TSB about the oil. I have seen this attached 'brochure.'
Old Oct 19, 2018 | 03:59 PM
many birds's Avatar
2013 GL350
Based on my experience with a 2013 GL350, I cannot recommend keeping/owning this car out of warranty. I have an apparent catastrophic engine failure at 95k mi, 2 wks out of CPO warranty (you can read about it in my other post). Quote for engine replacement at a dealer is $27k! Used low mile engines cost nearly $10k--IF you can find one and a shop to do the work. In addition to regular maintenance, during the warranty, it has needed turbo inlet seal replaced 2x, oil cooler seal replaced, DEF tank replacement due to heater failure, NOx sensor replacement, transfer case seal replacement, and I'm sure I forgot some other random item. And I drove the car only on long highway trips during my period of ownership.
But yes it has been a very comfortable vehicle--when it is running and not sitting at the dealer.
Old Oct 19, 2018 | 06:57 PM
  #32
What caused the catastrophic engine failure? I'm approaching that 95k milestone in my 2011 and have gone through similar repairs to yours.
Old Oct 19, 2018 | 09:35 PM
  #33
Dinismb's Avatar
2005 Mercedes C230 Kompressor, 2008 GL 320 CDI, 2008 ML320 CDI, 2016 GLE 300d AMG Night Package
Did you put a new engine or a used one?
Old Oct 21, 2018 | 12:32 AM
  #34
many birds's Avatar
2013 GL350
Dealership service manager did not know the specific cause of "catastrophic failure". He only mentioned that the crankshaft was loose. I asked if he meant that there was excessive play at the main pulley. He replied yes. He stated that they did not open anything up to come to their conclusion. I also asked if he was aware of a Chrysler TSB relating to the OM642 where the front main bearing fails after an oil change. He said he was aware, but wasn't sure if it applied to my car since they did not check into the main bearing. Currently, the car is at the dealership. I will have it towed home and will take a deeper look into what has happened. I do believe that before giving someone a $27k estimate for engine replacement, the dealer should have done a more thorough root cause analysis. My thought is that if this was under warranty, they would have looked very carefully at what caused the failure.
Old Oct 21, 2018 | 11:07 AM
  #35
BlownV8's Avatar
E55, GLS450, GL63, GLE350
Do not pay for a new engine if it needs one. Find a good used engine and get rid of the diesel GL. The OM642 has been plagued with serious issues for quite some time.
Old Oct 22, 2018 | 08:19 PM
  #36
Jpkcpa's Avatar
2013 GL350
So is it possible to replace a Diesel engine with a gas engine??
Old Oct 22, 2018 | 09:07 PM
  #37
No. They have completely different emissions systems, software, etc. everything.
Old Oct 25, 2018 | 07:12 AM
  #38
DC-BENZ's Avatar
Do you recall at what mileage each part failed? 3 of the 5 issues you had happened to my W164 Bluetec but the engine didn't fail. I sold it at ~120k miles.
Old Oct 25, 2018 | 07:14 AM
  #39
DC-BENZ's Avatar
Where is this Chrysler TSB?
Old Oct 25, 2018 | 10:44 AM
  #40
many birds's Avatar
2013 GL350
Jeep TSB: 09-001-08
Old Oct 25, 2018 | 10:48 AM
  #41
many birds's Avatar
2013 GL350
I don't remember the exact mileages, but I can give a rough estimate
Turbo inlet seal: 75k
Oil cooler seal: ~75k
DEF tank replacement: ~79k
Transfer case output shaft seals: ~85k
NOx sensor replacement: ~95k
Old Oct 25, 2018 | 08:17 PM
  #42
DC-BENZ's Avatar
The turbo inlet seal is that red $25 part right? Mine failed on my 2010 but I bought the Sprinter version as a replacement.
The Oil Cooler and DEF tank (which I replaced in 30 mins myself) failed around the same mileage as yours, in my 2010.
This time around, in my x166, I anticipate the Oil Cooler and DEF to fail again. I should be at the 70k mark just in time for Christmas. .
My NOX was replaced under warranty at 20k miles and 40k miles.
Old Oct 28, 2022 | 10:13 PM
  #43
olesouthernboy's Avatar
2015 GL350, 2013 GL350, 2002 ML320, 1983 E300TD-D
Digging up an old one.
178K miles and purring right along. Had the exhaust after treatment done. Bought the GL350 with 96k and have serviced it well. Oil changed every 5k with Rotella T6 5w-40, replaced the transfer case chain due to no fluid (oops)(chain only), trans fluid every 30k’ish, differentials serviced when trans serviced and it’s showing an average fuel economy of 27.2 mpg. Love the car and plan on it running to 300k without any problems.
Now, I travel a 3 state territory and when it cranks up my shortest trip is an hour down the interstate. This week was over 1k miles. I agree, these are not city vehicles.
**3/2023**
Update - Just turned 190k, no problems. Now, the front lower control arm bushings are starting to get stress tears and will be replaced in the next few months but that’s just wear & tear stuff in my book.
**10/2023**
Update - just turned 210k, replaced front end parts struts, ball joints, the works. None of it really needed doing but now I know…… Other than that maintenance, nothing but oil changes @ 5k. Think the motor mounts are done, again maint stuff. Oh yeah, dash display crapped out. Got an eBay unit for ~$100. MUCH better than the $1,700 price from the dealer. Only downside is it does not show the vehicle mileage.
Old Mar 17, 2025 | 09:24 PM
  #44
**3/2023**
**10/2023**
**3/17/2025**
sitting at 263K, Has a broken right side exhaust manifold which is getting replaced next week & I replaced the A/C compressor 10-15K miles ago. Still using no oil between oil changes. Needs the transfer case chain changed, again, which I have and will do it in the next month or two (will be #3). .
Old Mar 22, 2025 | 11:21 AM
  #45
Chrome988's Avatar
2012 MB R350 Bluetec
**3/17/2025**
Thank you for the updates, I enjoy reading them. I am 200k miles on a 2012 r350 bluetec. What symptoms do you get when your transfer case chain goes bad? I have never had that happen before.
Old Apr 23, 2025 | 05:54 PM
  #46
DC-BENZ's Avatar
I had 2 exhaust issues the manifold and the down pipe from the Turbo. At the time there were no new downpipes available in the world so I had to find one on ebay. I currently have a oil leak, I hope it's not the oil cooler again. I'm only at 120k or so.
**3/17/2025**
Old May 3, 2025 | 11:46 PM
  #47
You will hear the chain jumping teeth on the gear under hard acceleration especially when turning and mashing on it. I have either read it on a forum or a tech bulletin that the chain should actually be replaced every 60k miles. Not sure if I buy it but I am at ~100k on the second chain that needs replacing. My car is an interstate queen so 60k of more strenuous city driving might be the number especially on the diesels due to the torque they develop.
Old May 5, 2025 | 11:28 PM
  #48
AutomationJunki's Avatar
GL550
Any 200K miles?
I got my 550 to 197k miles on the original motor
Old May 16, 2025 | 05:00 AM
  #49
Mahomed's Avatar
Originally Posted by KrustyKustom
While my GL350 is a X164 I have the same drivetrain essentially. I have 126k miles, with the last 25k being the best, most trouble free miles yet. I think between 55k and 85k I replaced everthing that is typical on a diesel GL. Since they are not selling any in the states I am going to keep this one running and may scoop up another. Just too functional for a family hauler-tow vehicle that gets great mileage and love that low end grunt..
What would you estimate you've spent on the car to date for maintenance?
Old May 16, 2025 | 06:19 AM
  #50
GL550
Last edited by AutomationJunki; May 16, 2025 at 06:21 AM. Reason: thought it was to me
