Switched power fuse - which one?
Have searches multiple phrases for radar detectors and dash cams but not finding anything. Thanks in advance.
Here's an old post on my dashcam installation: https://mbworld.org/forums/gl-class-...ml#post6591787
https://mbworld.org/forums/gl-class-x166/543857-radar-hardwire-gl-350-a.html
Last edited by Pntblnk; Apr 11, 2018 at 10:09 PM. Reason: corrections to switched fuse #
I just completed the hardwire install of my Dash Cam in mt 2015 GL450
**** The Fuse Block A, located in the Engine compartment - Passenger side is where the Switched-on power block is located.****
The whole right side section which has the fuses for the Headlights are all Switch-on.
In addition there are approximately 5-6 blank connections where there are no fuses connected are also switched on.
I remoced the under dash cover on the passenger side and
1. Found a rubber grommet where the FAT RED Main Battery cable comes into the cab through the Firewall.
2. used a very thin hanger to push through the grommet
3. found the hanger coming through the firewall into the engine compartment pulled it back a little
4. taped the power supply wire with a in-line fuse, snaked it too the fuse box
5. Installed a Male spade terminal en to the wire and plugged it in to the fuse block.
The rest is the easy stuff, snaked the wire from the camera next to the rear view mirror to the passenger side along the top of the wind shield moulding and down the RH pillar and into the area under the passenger side dash.
My 2015 has a little door for the Body VIN #.
I placed the wires and the fuse behind the cover for the VIN # and will have easy access for any future additions and access to the fuse if necessary!
It took me an hour from locating the Box, testing the Switch-on power and installing the wires...
I will try to add pics later on but...
The brown and red wires in the overhead console is NOT the solution for the Switch-On power supply.
If you have any questions, feel free to write.
You state that you removed the under dash cover. Can you please advise how you did this?
TIA.
TIA.
