Clicking on hard turn
Old May 2, 2018 | 09:24 AM
srfrboy's Avatar
2013 GL550 4Matic
I am getting a clicking sound from the drivers side front end of my 2013 GL550 at very slow speed when making a very hard right hand turn. For example, when pulling into a parking spot. Happens very randomly and haven't heard it in a long time until yesterday. CV boot isn't torn. Any thoughts...?
Thanks...
Old May 2, 2018 | 07:19 PM
spoole100's Avatar
2015 GL350
Had similar issue with my GL350. IIRC dealer replaced and repacked bearings.
Old May 2, 2018 | 10:34 PM
mercup's Avatar
I would agree...it sounds like a potential bearing issue. Especially if you can feel the click or pop in the steering wheel. Typically in a turn if the outer wheel clicks or pops then good chance it is bearing failure, if it is the inner wheel that it is making the noise it can be a problem with how well the bearing is seated.
Old May 3, 2018 | 08:24 AM
SaniDel's Avatar
2015 GL 550
Any chance it is the left front tire contacting the wheel well liner? This sometimes happens when I have the suspension raised while doing slow speed maneuvering, e.g., positioning the vehicle at the car wash tunnel.
If you are riding on Continental tires mounted on 21" wheels there's not a lot of clearance in the wheel wells when they are full lock!
Old May 4, 2018 | 09:05 AM
srfrboy's Avatar
2013 GL550 4Matic
Thank you for your comments and thoughts. I will be going to my independent shop to see what they say.
Old May 4, 2018 | 11:47 AM
mercup's Avatar
Good point...certainly anything outside of the standard factory wheel/tire combo could contribute to the noise.
Old May 4, 2018 | 06:24 PM
srfrboy's Avatar
2013 GL550 4Matic
I am riding on 21's, but DWS '06's... I'll have to check for that... I didn't think that it sounded like that type of noise. But it is so intermittent that it might be that.
Old Oct 26, 2019 | 07:31 AM
bar-ah's Avatar
GLS63
Did you resolve this issue?
