TSB M278 engine cylinder #5, #6, #7 & #8 left bank cylinder misfire
Old Oct 26, 2019 | 04:22 PM
zeroroadkill's Avatar
X166
Exclamation TSB M278 engine cylinder #5, #6, #7 & #8 left bank cylinder misfire
Quote:
Originally Posted by BLK GL550
Does anyone know if a TSB has been issued for either the valve stem seals or transmission clunk on M278? I also have 2013 GL550 with 65K miles. No issues so far with either. My CPO warranty runs out in November.
Yes there was a TSB on this issue dated 08/06/2015
Topic l101.30-P-061835
01.30 cylinder head
M278 engine with numbers after 2789xx 30 128000
Fault codes: P030085, P030585, P030685, P030885, P030785
I just had my 2015 M278 engine removed and replaced the left cylinder head @ 57K miles. Cylinder #5 misfire. 2 months left on the warranty!!!
If this happened after the warranty lapses would MBZ cover it???
After reinstall of the engine, left turbo coolant line (hot side) leaked so had to replace tubing.
The engine was power washed to clean off sprayed antifreeze. Still see steam coming from fender well/hood after hard run. Smells like burning antifreeze. Dealer says wait a few days, it might be pooled water from the power wash! We will see...
Old Oct 26, 2019 | 06:26 PM
Forrest Gump 9's Avatar
shrimp boat
I’m betting there are more than one turbo coolant lines got snapped. Iirc, there are four lines three are plastic and one metal. Good luck
