Can I replace this myself?
Old May 7, 2018 | 06:48 PM
ScottBaer's Avatar
2016 gl450, 2016 c300 , 2019 glc 300 Coupe, 2024 AMG GLE 63S
Old May 7, 2018 | 07:16 PM
MaschioneCazzuto's Avatar
2016 E63 AMG-S, 2007 FERRARI 430, 2001 JEEP WRANGLER 60TH ANNI. EDITION SOLD 2011 E550 4matic
Does this stuff occur to you by random.
Old May 7, 2018 | 07:51 PM
ScottBaer's Avatar
Haha!
Story with the plate is...
got wife personal plate for her new car several years ago
she didn’t like it and said “I just want a random one”
Old May 7, 2018 | 08:19 PM
ItalianJoe1's Avatar
2003 CL 600
That trim strip just pulls off, yes you can replace it yourself if you're a little careful. Best bet is to work slowly with a plastic trim tool until you get it unclipped enough to not damage the bumper. You can go behind it (under the car) and press up the tabs to help it pop out, it will be in there pretty tight.
Old May 8, 2018 | 11:33 AM
chsu74's Avatar
GL 450, 993TT, Cayenne Diesel, 964C4
Yes. It should pop out with a trim tool if you are careful. Wife hit the only utility pole within 100 yds of the house the other month and cracked the reflector on the rear bumper. Easy replacement.
Since you are replacing the strip, should be no issues breaking the broken piece off. You should be able to see the inside of the bumper if you crawl underneath the car.
