Front Grill Removal Help
Hi all
Does anyone know if the grill can be removed without having to remove the front bumper cover to get access?
I asked my local dealer to print off the instructions and he said he would but theres a lot because it starts with the bumper removal, which Im surprised about, is that really necessary?
I have distronic but assume that has no affect on the need to remove the bumper and having watched videos of other models in the MB range i thought it would unclip and lift up and out, anyone know?
Model is GL63 AMG
Carl
Model is GL63 AMG
Carl
kblair3d (09-14-2020)
I cant seem to see that in your build thread, I saw you mention it pulls out from the bumper with some clips up and some clips down but i couldnt see any pictures of the access from the front slam panel etc.
I have distronic, is it easy enough to unplug it?
Carl
Carl
2012 Volt - 2005 E55 - 2011 G55 - 2013 GL63
Yeah pull the plastic trim piece that has the Mobil oil stickers on it off. Secured with some push rivets. Then you can see behind grill the tabs. Again some push up and some down if I recall. Not too hard. The distronic puck is mounted and out is the way behind the star. Only hard part I had was the 360 cam has like 3 clips and I broke on getting it off. Didn’t affect putting it back on and it’s plenty secure.
did you manage to remove your front grill? if so, can you send me the instruction to do it? I also don't want to remove the bumper if I don't have to. my model is 2019 GLS63 AMG
