Bluetooth audio
whenever music playing via Bluetooth, it’s cutting off, every +- 10 sec it’s silence(0.2 sec) then continue playing.
No it’s not my internet connection, I try different devices and home WiFi.
It just keep cuting off. And it’s not always like that, sometimes it will play flawless, sometimes it’s impossible to listen.
What would be your suggestions?
Vehicle still under extended waranty but I need somehow to show them what’s wrong, and I’ll go to dealer and it will work
btw they wont do **** until there’s a check engine code.
Tried my wife's Note 8 a bit less interruption but mine is like every 10 seconds so frustrating Dealer told me tech tried same phone and it worked fine, problem is that when you pair at first it's fine, but after few minutes the interruption gets back on I personally listen to Google Music and YouTube music but no matter what I stream or play through Bluetooth every 10 sec it cuts out..
You have to go to Settings Device Maintenance under 'Battery usage' Select menu from there go under 'Optimize Battery usage ' and uncheck Bluetooth and all of your playing apps suc as Google Music or YouTube music and that will eliminate the annoying skipping on songs.
Appreciate letting me know - thanks !
