Turn signal stalk acting up
Many thanks for the information. Another question, where do you usually buy the part? The manufacturer's price (from mbparts.mbusa.com) is about $665. I found there are a couple of OEM parts selling online at ~20% discount (e.g., www.oemvehicleparts.com), but I am not sure how good they are.
My local dealer is 2mi away but everything is marked up 3-5x, its crazy. Never shop there unless I'm in a huge rush and they've got the part on the shelf.
Mekantor, could I get some assistance with my VIN and the proper turn signal assembly?
I too have the issue with the blind spot, lane assist, and all other systems failing as well as turn signals. I do have an internal torque control module code. I’m hoping this will fix the issue.
4JGDF6EE7FA612475
thank in advance @mekantor
4JGDF6EE7FA612475
4JGDF6EE7FA612475
4JGDF6EE7FA612475
6172crew (09-26-2022)
awesome. I’m hoping this will take care of my issues. Awhile back the wife complained about all 3 drivers assist systems failing and now it happens more frequently. I broke down and purchased a Autel 906S because my eld readers don’t seem to give much info on this newer X166. Who knows, maybe I have 2 issues, the internal torque control module and this multifunctional switch but my dealer here isn’t a place I trust. I have an extended warranty but with my EC tune I’m certain they will point to that as being the problem.
thank you for getting me the proper part number, I’d hate to get the wrong one.
6172crew (10-02-2022)
@6172crew torque converter errors sound like they're related to the transmission control module.
If you're in the Houston area at some point with that car, get a hold of me and I'll look at it with Xentry.
#32
Typically I shop for OEM parts at benzpartshq.com, which is a MB dealer in Florida. Their prices are close to the lowest wholesale I've typically seen. For your part, looks like ~$500.
#33
Thanks for the information. I ordered and received the part. I just went to a nearby repair shop for the replacement, and they told me that extra efforts such as zero-point calibration and 4-wheel alignment are needed for the replacement, which charges $700 for labor. Are these essentially necessary? Or I can ask them to simply replace the multi-function switch only?
A full alignment at the dealership would be much less than 700.
qizhou (10-28-2022)
#34
I waited a bit before posting but I bought a Autel 906S and ran some tests on my X166 GL450 and the problems went away. Odd, but I wanted to pass along the info.
The test I ran was the live functions tests for the steering wheel as well as reset my suspension from the hot functions. It has been 2 weeks since I had the "don't drive, go to dealership type messages come up.
oldmangrimes (11-01-2022)
#35
#36
#37
Hi, i have same issue. Kindly send me part number based on my Vin 4JGDA5HB8GA670543. Thanks
8Q96 - ESPRESSO BROWN
#38
#39
They have a MB Nigeria website, and it lists dealerships in the country: https://www.mercedes-benz.com.ng/en/...locations.html
#40
Not sure there, but you're probably better off ordering more locally, or from Europe.
#41
Have a fault code for both Steering column and the Instrument Cluster control module
do these share wiring?
#42
C074700 n80 for the steering control module
and DTC u0155
The needles in the Cluster itself works fine but randomly blind spot, distronic + and PreSafe go inop.
Nominal voltage is 14.8
Voltage at time of Fault/DTC: 14.7-14.8
and DTC u0155
#44
Are you reading these with Xentry or juat a OBDII scanner? Cluster doesn't run those systems, just an info display. To me it sounds like the same steering column module issue as others have experienced.
#45
#47
Hey Mekantor If you're still doing this could you grab the part number for vin 4JGDA5HB8DA235243
#49
#50
Good luck!
