Turn signal stalk acting up
I'm hoping that it just has some dirt on the contacts which can be cleaned, otherwise the entire Multi-Function Switch assembly has to be replaced.
Update: Xentry says B178F00; seems like the usual answer is to replace the entire thing, I'll try a repair before throwing $500 at it.
I had some uncertainties going in, but decided to proceed anyway and these were mostly resolved:
1) First time removing the airbag is a blind operation, but basically there is a "channel" inside the steering wheel, so if you insert a flat-head screwdriver parallel with the plane of the steering wheel and push it on the spring you'll see the air bag pop out. You should feel some soft resistance, if you bump something firm then its in the wrong spot.
2) Steering wheel bolt - I didn't know what it would be, turned out to be a big hex which I didn't have (slightly larger than 3/8), but a T55 torx worked. WIS says to replace the bolt, I just put fresh loctite on it, might replace it in the future. Its on tight, I had to use a 1/2 breaker bar to remove.
3) Module's connector - it has a self-destructing tiny clip securing it in place. Best to have a spare handy, I ended up carefully super-gluing it and reused it.
4) Programming - I was concerned it would require online coding, but it just worked automatically without any xentry programming.
Steps:
1) Set wheels straight. Move steering wheel into a mid-height position, and into the dash a bit as it will give you slack on the module connector.
2) Disconnect negative cable on primary and aux batteries
3) Wait a few minutes, remove airbag. Be very gentle with it, please be safe, it has explosives, and absolve me of all responsibility in writing, with a notary, prior to starting this.
4) Remove steering wheel, get helper to counterhold if you're having trouble breaking the bolt.
5) Remove module after unclipping the soft cover
6) Install new module, unclip the red shipping retainer prior to replacing the steering wheel.
7) Reverse steps 4-1
The old clip, I couldn't even read the numbers on it, but they weren't in a typical part-number format
Edit: the clip part number is A0008230245, thanks to Yeffsy for ordering it to confirm (reference post).
just replaced the failing unit with one from a salvage yard that came off a 2014 ML. Took maybe 15 minutes and only cost $150. Working perfect for now.
The message started showing up during some long distance trips so until I complete one of those, I am not certain if this replacement worked but so far so good.
Here are some info I would like to share from my work.
@mekantor's instructions above were valuable so thanks to him. I found a video that helped me and here it is:
I never open up my battery before and learned that it was replaced once so it was good to know. Disconnecting the main battery took me like 30 min to get to it. One tool that came in handy is the plastic pin puller. There was a plastic pin that holds the blower outlet and the battery cover. Disconnecting the auxiliary battery took me like 15~20 min because I watched one video that told me to get to the back panel with torq screws but later realized that it is not really needed. You can just move the padding down to get to it.
As mekantor mentioned, took me almost 30 min to take the air bag out. I couldn't find the metal spring to release. After watching several videos and studying the angle, I was successful. Don't force anything. Once you find the spring mechanism, it pushes in without much force.
I also had to use my breaker bar to unlock the main steering lock screw.
I broke the small clip in mekantor's picture as well, but decided not to put it back in because even without it the connector is pretty secure with a locking mechanism.
Took me total of about 4~5 hours.
so far it has not happened again but my problem started to happen during long distance trips and i have not had a long distance trips since replacing so the jury is still out
i tried to find the part number but i cannot seemed to find it. some numbers on the part doesn't show up on google. what i did was to find a used part on ebay with the entire control module. i just took the signal module off of it. hope that helps.
MERCEDES]W166 X166 ML350 STEERING WHEEL CLOCK SPRING SWITCHES GEAR SHIFTER OEM
A 166 900 96 00, A1669000108 A1669000703
Seems the part number of my car is A166 900 04 08 9051 (includes all options, color: black) for anyone who finds this thread and needs to know. Found online for $419.21 here: Multi-Function Switch - Mercedes-Benz (166-900-04-08-9051)
