Enabling DVD and Nav address entry while in motion
Old May 8, 2019 | 02:55 PM
info@bimmerguru.com's Avatar
Former Vendor of MBWorld
G11
BimmerGuru provides a simple software unlocking to enable video in motion on the GL. No need to install hardware. Takes less than 5 minutes and can be restored back to factory settings. Here's a video on how it's done:
Old May 8, 2019 | 06:41 PM
DaveW68's Avatar
Veteran: Army
2015 S550
How much?
Old May 8, 2019 | 06:43 PM
G11
Originally Posted by DaveW68
How much?
Hi Dave feel free to check the prices on https://bimmerguru.com/benz
Old May 11, 2019 | 12:11 AM
mercup's Avatar
Anticipate having a GLS version anytime soon?
Old May 11, 2019 | 10:49 AM
G11
We are still working on a solution for the GLS, unfortunately I don’t have an ETA for now
Old Oct 27, 2019 | 01:25 PM
JAbinader's Avatar
gl550
Has anyone purchased this software ? I’ve been looking into it. Any problems ? Success ?
Old Oct 27, 2019 | 01:32 PM
G11
hi what year and model is your MB?
Old Oct 27, 2019 | 02:51 PM
JAbinader's Avatar
gl550
2014 gl550.
will the navigation work as usual if I switch between Navi and video ?
QUOTE=info@bimmerguru.com;7887972]hi what year and model is your MB?[/QUOTE]
Old Oct 27, 2019 | 03:03 PM
G11
2014 gl550.
[/QUOTE]
your car is supported… If I recall correctly the navigation will work in the background while you’re on video… Since this is a video in motion software only and does not alter affect any other feature the best way to test is to put a destination address in your GPS and play a DVD and drive around the block to see if you can toggle between the GPS and the BLOCKED video screen , if it works then the video in motion software will enable it to show video while driving
Old Oct 27, 2019 | 03:15 PM
JAbinader's Avatar
gl550
thank you.
your car is supported… If I recall correctly the navigation will work in the background while you’re on video… Since this is a video in motion software only and does not alter affect any other feature the best way to test is to put a destination address in your GPS and play a DVD and drive around the block to see if you can toggle between the GPS and the BLOCKED video screen , if it works then the video in motion software will enable it to show video while driving[/QUOTE]
Old Oct 29, 2019 | 12:15 PM
silkysmooth_96's Avatar
2014 GL350
I purchased it 4 years ago. has worked flawlessly and never had to think about it again. Easy to activate, no hardware etc.
Old Oct 29, 2019 | 12:22 PM
JAbinader's Avatar
gl550
Great !! Thank you. I decided to purchase it. Waiting on SD card to install.
