MB Brake fluid level sensor BS
remove dust cover
remove one torx screw for drain and remove plastic drain.
pinch these two tabs together and push inward.
The sensor is on the bottom. 1st, unplug the wire connector. To remove teh sensor, pinch the two tabs together and push out. It will be stopped by a detent. Use a small leverage tool to put behind the the tab and push it towards the front to release it from the detent. remove and replace.
Fit For 2011-2018 GRAND CHEROKEE DURANGO BRAKE FLUID LEVEL SENSOR NEW OEM 68102030AB
https://a.aliexpress.com/_mqkJlQF
"]https://cimg6.ibsrv.net/gimg/www.mbworld.org-vbulletin/960x1280/nkaaage7fua_960_61115a4bb60c5fbc85e337123777519236 e6017f.jpg[/img]
Someone must know something about this switch
