2014 GL 450 has a code P001885
Old Aug 16, 2019 | 12:30 PM
zbabar's Avatar
2014 GL 450
Hello everyone,
New in this forum. I have GL450 has 108k miles year 2014 code P001885. ( the position of intake camshaft cylinder bank 2 is implausible relative to the position of crankshaft . there is an implausible signal).
Has any one this issue please reply .
thanks.
Z
Old Aug 16, 2019 | 01:18 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
moved to X166 forum...
bad camshaft sensor??
Old Aug 16, 2019 | 03:18 PM
zbabar's Avatar
2014 GL 450
Hi
I swapped the sensor to the other side but the check engine light came back. So its not sensor.
Old Nov 14, 2019 | 09:59 AM
ps_automotive's Avatar
2014 GL 450
2014 Mercedes GL 450 Camshaft Position Sensor & VVT Solenoid Location
Old Nov 25, 2020 | 01:57 PM
Importeurotech's Avatar
None
2014 ml 350 4matic;;;; etc p001885 bank 2 intake cam implausible signal....
Originally Posted by zbabar
Hello everyone,
thanks.
Z
What did you find???? I'm at my wit's end!!!!!!
Old Nov 27, 2020 | 12:18 PM
None
According to the previous tech,,,, he got the car with that one and only code.... he did everything Benz suggested and still got the same code.... runs and drives out fine... When code p001885 is cleared car starts right up but the code comes back the minute you start it.. after the code sets,,, you have an extended crank before start up... I checked the signal of the left bank intake cam sensor and compared it to the right bank intake signal,,, both are the same square wave except they both show intermittent spikes..... mileage is 142302... HELP!!!!!!
Old May 23, 2023 | 01:06 PM
ans's Avatar
ans
mercedws cls 350
Same code
Hi guys did somebody fix it?
Old May 24, 2023 | 12:34 AM
arsupisemnet's Avatar
2014 GL450, 1992 W140 300SD, 1993 W140 300SE, 1987 E30 Convertible
The fix for this issue is to take valve cover off and check relative position of camshaft sensor plates. Camshaft sensor plates are pressure fitter, sometime some of them slip off and that is the error given to you - one of the camshafts is not aligned with crank
Old Apr 7, 2024 | 12:31 PM
jbrowniii's Avatar
2013 E550 4matic
P001885 on 13 E550
I have the same exact issue. Car starts up quick and runs fine but once that code appears, it hard starts. I've changed all camshaft position sensors and two of 4 magnets. Was about to change the last 2 before reading your posts. I'll give it a try. Thanks.
Old Apr 22, 2024 | 09:20 PM
jbrowniii's Avatar
2013 E550 4matic
P001885 on 13 E550... FIXED... (Bad Camshaft position sensor)
In my case I had recently changed the Camshaft position sensors from FCP Euro so it never crossed my mind that one could be bad. I looked through my old sensors to find the cleanest one. Changed the O ring and swapped one on cylinder bank1 first. Cleared the error and started the car. Error came right back so I cleared it and swapped the sensor on bank2. Sure enough, that was the culprit!! I stopped and started the car about 10 times. The error never came back.
