2015 GL350 BlueTEC - Engine Temperature
I recently noticed mine was running at around 10 while city driving. Since it only goes upto about 15, I thought it was too hot. Any ideas?
I’ll keep monitoring and try to post pictures.
If you are seeing wild changes in temp once the engine is warm, or extremes (hot or cold), then that could indicate an issue that requires more troubleshooting.
p.s. my USA-spec GL350 temp gauge is in Celsius and the engine is usually regulated around 90C. (The engine is still cold in the attached photo.)
I was initially worried because I thought most auto manufacturers design the temperature gauge so that the engine operates at around the middle, which would be 80 in this case. When I saw it go past the halfway point I was starting to worry but I guess it’s normal.
Under heavy load it can go 95-100 - by heavy i mean all the way to the floor.
