Clear Liquid Leaking Below Car in 2 Spots, Possible DEF Leak?
Old Nov 26, 2019 | 07:05 PM
Patel151's Avatar
2014 GL350
As the title mentions, my 2014 GL350 Bluetec is leaking some sort of clear fluid. I recently had my NOX sensor replaced because my car had "xx Remaining Starts", and a week later I got "Check Adblue" and then had "xx Remaining Starts". Took it back to the dealer and they checked it and said nothing was leaking but there was dry Adblue by the injectors? Anyways they refilled the Adblue to the top and I get home, there is some sort of clear liquid leaking and I'm pretty sure it isn't the A/C because it was off, but the heat was on in the car. Does the heat cause dripping or just A/C, or is the DEF still leaking? It's weird because I noticed the leak a few days after I got the NOX sensor replaced. I initially took it in after replacing NOX sensor because there was a dried out liquid on my driveway and I'm pretty sure it was an Adblue leak. The leak seems to be coming from the little hole in the first picture beside the silver thing.
Attached Thumbnails Clear Liquid Leaking Below Car in 2 Spots, Possible DEF Leak?-a05500d5-e054-4cb5-86fa-3380f182611f.jpeg
