Brake Rotors, Pads
Has anyone found a brake rotor paint, for the tophat, that last long enough to keep rust away?
https://www.rockauto.com/en/moreinfo...&jsn=22&jsn=22
According to Powerstop, the correct rotors are 1463. however these are sold out everywhere.
According to Rock Auto, Carpart.com, Amazon, the correct part is 1461.
Apparently 1463 is the AMG rotor? did i read correctly that the amg and regular rotors are the same size?
Any thoughts?
EBR1463 is 13.78 cm diameter
EBR1461 is 14.76 cm in diameter.
Strangely, the AMG and standard have the same brake pad.
Also, for the upgraded rotor, P15EBR1600XPR, the powerstop website lists both AMG and non-AMG as fitments. These are 13.58cm diameter.
https://www.powerstop.com/search/?part=EBR1600XPR
2014
2014 MERCEDES-BENZ GL3502014 MERCEDES-BENZ GL450 AMG Performance Pkg
2014 MERCEDES-BENZ GL450 Except AMG Performance Pkg
2014 MERCEDES-BENZ GL550
Perhaps the 1cm difference in diameter does not matter?
The VIN is 4JGDF7CE8EA362428
End of the day, what is the correct fitment? With different search results from multiple website and Powerstop not having an answer either, maybe I just need others. Zimmermann?
2014
14.76 is not in "cm" but in "inches" - 14.76" front rotor (GL550) which is 375mm (37.5cm) diameter
Aside from Brembo, does anyone else have a recommendation for rotors?
My understanding is that Zimmerman is the suppler for MB for these rotors. They are identical to the MB ones I had on before.
Here is that set with Meyle pads: https://www.ebay.com/itm/152705531582
