Coolant smell usual suspects.
Let me know if you been through this with the truck. I can’t pin point it, but the smell drives me nuts.
The circulation pump on my M276 W166 emits a coolant-smelling vapor, but I have yet to see a drop of liquid leaking out. The small diameter hose connections from the reservoir to the circulation pump and down to the radiator bottom hose seem encrusted with dried coolant. Have a look there.
Pressure testing may help also.
You mention the turbo cooling lines, have they been replaced? If not, they are leaking, even if you don't see it. If you press on them they will snap off from being so brittle due to age/heat.
