PCV Catch Can (GL 350)
Old Mar 25, 2021 | 09:46 AM
asuchander's Avatar
2013 GL350 X166.824
Just put in a PCV catch can this weekend - not hard to do at all.. I used 5/8" heater hose and some 5/8" 90 degree angle brackets to pipe it in alongside the engine
Pics here.
Made an aluminum bracket to attached to the fuse box
Backside of bracket
Bracket in place
Bracket in place
Used rivets to attach the catch can bracket to the bracket I made
A bit too high - I lowered it later (not this pic)
Catch Can In place
Mishimoto catch can
Old Mar 25, 2021 | 09:47 AM
asuchander's Avatar
2013 GL350 X166.824
The bracket just slips on and off (it's fairly tight) the fuse box), between gravity and friction it'll stay there on its own without any fasteners. Makes it easy to pull out and drain I hope.
Old Dec 4, 2024 | 09:46 AM
RollTideW163's Avatar
2014 GL450, 2006 S500, 2003 ML350, 1996 C280 (Prev 1995 C220, 2002 CLK320, 1980 300SD Turbo)
Sorry to bump an old thread - but can any one provide more info as to where the hoses go ?
Good job on the bracket asuchander.
Old Dec 4, 2024 | 08:30 PM
asuchander's Avatar
2013 GL350 X166.824
thanks.
So off the the air intake there is a outlet for air coming from the PCV valve. I cut that hose - and then added in some clamps and hoses to run to the catch can. So the air comes out of the PCV, goes through the catch can, and then back into the air intake next to the turbo.
