Airmatic question
Old May 4, 2021 | 11:45 AM
DrDP's Avatar
2014 GL 350
Airmatic question
Hi Members,
Need help!
Airmatic malfunction?
Heard hissing noise from left rear wheel - found big cut in air spring. I went ahead and got Arnott air springs and had indy replace both rear air springs. After install he said need to change compressor as it did not fire up so replaced compressor (also Arnott). Now the car still shows airmatic malfunction. the raise button raises the car but does not lower it.
Also what the factory recommended height setting for airshocks - indy set at -40mm at all 4 corners but seems low to me and ride quality is ****.
thanks
Old May 10, 2021 | 09:43 PM
tritron's Avatar
cl500
I assume it related to high sensors ?
Old May 11, 2021 | 12:36 PM
chassis's Avatar
2017 GLE350 4MATIC
Throw new level sensors at it?
Old May 12, 2021 | 06:06 PM
mikapen's Avatar
Haha. Now you're sounding like that Indie Shop with pipe wrenches (Just kidding)
Old May 25, 2021 | 05:01 AM
rhayder's Avatar
GL450
Valve block. You probably did not need a compressor. That's my guess.
Old May 26, 2021 | 08:13 PM
nero550's Avatar
2010 gl550 , 2017 gl 63 amg
sensors do not go bad that easily, start by getting the vehicle recalibrated.and an actuation test.
Old May 26, 2021 | 10:35 PM
rhayder's Avatar
GL450
Be prepared with parts. Mine would not recalibrate so that is why I am replacing the valve block.
