Airmatic and Suspension
Old May 30, 2021 | 07:48 PM
Columbus430's Avatar
GL450
I've got an issue with the Airmatic. Most of the time the rear end settles after it's parked. From the research I've done it looks like one of the rear air bags has a leak. Looks pretty easy to replace and a pair of Arnott's are about $300. I might even attempt it myself, Youtube makes it look easy.
My question is should I also replace the rear struts? I have 138k on a 2013 GL450 and they are a maintenance item. I will be pulling a trailer.
Old May 30, 2021 | 08:28 PM
BlownV8's Avatar
E55, GLS450, GL63, GLE350
I would do it all at once for extra safety. If you are riding on the original shocks, they are most likely in need of replacement or will be shortly.
Old May 31, 2021 | 06:47 PM
mikapen's Avatar
And the link bushings.
Old May 31, 2021 | 09:04 PM
BlownV8's Avatar
I would check them first for wear but it's probably a good idea none the less.
