GL550 lift?
2015 SL550, 2017 GLS 550, 2010 G550, 1995 E320 Cabriolet
GL550 lift?
Recently, business has me traveling through rural areas with choppy roads and huge snowfall amounts. I've been thinking about lifting my new-to-me GL550 and fitting some bigger tires along with some auxiliary lamps. I'm trying to figure out my options here and they seem to be the following:
-Fit larger tires on my otherwise stock truck: What are the largest tires I can fit with the stock suspension and wheels?
-Keep the airbags while figuring out how to keep them locked in the raised setting. Is there a way to do this? Or, are there "bigger" airbags that I can fit which gives the truck a taller ride in "normal" height?
-Ditch the airbags and fit springs that would give a 2-3" higher-than-stock ride. The air springs/adjustable dampers do give a great ride, but is this the only realistic option to get a taller ride height? Is there a way to keep the stock adjustable shocks if I go this route?
Also, if I do mount lights up front, what are my options in terms of mounting points and wiring?
Thank you!
Thank you!
JD101b (07-06-2021)
Check out this OBD plug/module. It's primarily for lowering, but can raise as well.
https://www.amazon.com/Mercedes-Susp.../dp/B07C7G3J13
The truck has a wider track than a GL450, and I'm thinking about fitting modest spacers, but is the suspension itself affected in any way?
I guess it's as safe as any other suspension lift. Raised center of gravity, altered suspension geometry, increased driveshaft angles - but whether or not 2-3 inches that you want to lift will make a significant difference, I don't know.
