Turbo Removal
Old Jul 7, 2021 | 09:45 AM
silvergl's Avatar
GL 450
Turbo Removal
Do anyone know how to remove the oil lines from the turbos? I have removed the bolts, but the oils lines are still in there pretty good, you can spin them but not pull them out. I thought I would check with you guys before I put a tool on them and damaged them.
Old Jul 7, 2021 | 09:51 AM
arsupisemnet's Avatar
2014 GL450, 1992 W140 300SD, 1993 W140 300SE, 1987 E30 Convertible
If it is steel braided hose just pull it out. Rubber o-ring just become hard because of the temperature.
Old Jul 7, 2021 | 09:56 AM
silvergl's Avatar
GL 450
Thanks, i assume the low pressure, return hose is the same?
Old Jul 7, 2021 | 09:58 AM
Return hose is the one on the top. Supply hose is the one on the bottom. Turbo's has it's own mini oil pump.
It is no pressure as long as motor not running. Might leak some oil
